Engines Skipping, No CEL
Old Jun 2, 2011 | 12:20 AM
PikeFire216's Avatar
PikeFire216
Ok I have a 1998 F250LD with a 5.4. It has a bad skip in it but will not turn the CEL on. Any ideas on how i can check which cylinder is misfiring without the CEL being on? PLease Help
Old Jun 2, 2011 | 07:03 AM
projectSHO89's Avatar
projectSHO89
Use the scanner in Mode 06 to look at the misfire count PIDs for each cylinder.
Old Jun 2, 2011 | 08:26 AM
PikeFire216
I dont have a good scanner. All i have is an actron pocketscan
Old Jun 2, 2011 | 06:18 PM
projectSHO89
Then you'll have to either upgrade or hire someone with the correct equipment.
Otherwise, find the particular driving condition that exhibits the symptom, then really hammer on that condition and see if the PCM will finally declare a misfire and set the MIL.
Are you certain your truck is an "LD" and not the "HD"? Have you checked the emissions compliance label under the hood to see if it's an OBD1 or an OBDII emissions system?
Old Jun 2, 2011 | 08:06 PM
PikeFire216
No I havent, Where do i look for that and how will i know which one is which? Mine has the F150 body with the 7 lug wheels
Old Jun 2, 2011 | 11:31 PM
Ultramagdan's Avatar
Ultramagdan
You have the LD (a good truck IMHO) and should be OBDII. As SHO said, you can look on the label under the hood.
vtboy51
6.7L Power Stroke Diesel
Apr 29, 2011 10:03 AM
mylesdixon
Feb 18, 2009 10:06 AM
Beaned
Aerostar
Dec 15, 2008 05:56 PM
Pablo-UA
Aerostar
Dec 3, 2008 08:19 AM
Cool1996
13
Mar 4, 2004 06:56 PM
