Need help finding block plate
Old Jul 21, 2015 | 01:17 PM
pat420swed's Avatar
pat420swed
I am in the process of doing a c6 to 4 speed swap, and i am in a dillema since i cant find a block plate/ transmission to bellhousing seperator plate.
I have a 300 6 but i believe that one for a 302 or 351 will work fine as long as its for a manual transmission.
Anyone know where to buy one?
Thanks, Pat
Old Jul 23, 2015 | 10:54 AM
pat420swed's Avatar
pat420swed
Anyone have Any ideas?
Old Jul 23, 2015 | 01:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by pat420swed
I am in the process of doing a c6 to 4 speed swap, and i am in a dilemma since i cant find a block plate/ transmission to bellhousing separator plate.
I have a 300 I-6 but i believe that one for a 302 or 351 will work fine as long as its for a manual transmission.
302/351W is not the same!
C5AZ-7007-A .. 240/300 I-6 M/T Rear Engine Plate / Marked: C5AE-6A373-C or E7AE-6A373-BA or E8TE-6A373-BA / Obsolete
Applications: 1965/72 Galaxie/LTD 240 I-6 / 1965/74 F100/350 240/300 I-6 / 1975/96 F100/350 300 I-6 / 1981/92 Bronco 300 I-6.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
DON'S TRUCK SALES in Fairbank IA has 1 = 319-635-2751.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 41 = 800-476-9653 / 704-786-8139.
Old Jul 23, 2015 | 02:04 PM
pat420swed's Avatar
pat420swed
Im sorry i dont really understand what all that means?
Old Jul 23, 2015 | 02:12 PM
pat420swed's Avatar
pat420swed
I went ahead and ordered a universal ford small block block plate from summit racing yesterday, i am hoping it will fit even if i have to make minor changes, all this block plate really does is keep debris out of the housing and protects the inner parts right? Also i know it spaces the starter off the flywheel
Old Jul 23, 2015 | 02:13 PM
NumberDummy
Post 3: Geez Louise, I did all the work, all you have to do is read it.
C5AZ-7007-A is the correct Ford part number for the engine rear cover plate for a 240/300 I-6 with a M/T
I typed the 3 possible ID numbers stamped on the rear plate, listed the applications and found 43 NOS (New Old Stock), listing the sources/locations/phone numbers.
This plate fits between the engine and the bell housing, it needs to be there so the starter drive will line up properly with the flywheel teeth.
Rear plate shown as 7007 in pic:
Old Jul 23, 2015 | 04:03 PM
pat420swed's Avatar
pat420swed
Ok thanks alot for the imfo much appreciated, so i guess a 302/351 plate will 100% not work. Ok.
Sorry i didnt see where u listed that thosevshops had the part the first time i read it.
Just wondering, how did u figure out that those shops had the plates?
Thanks again fir the help
Old Jul 23, 2015 | 04:09 PM
NumberDummy
Sorry i didnt see where u listed that those shops had the part the first time i read it.
I'm having computer problems, the damn thing may work fine for hours, or it can lock any time, a PITA!
After I typed the part numbers, I went to see who had them, the damn thing locked up, so I had to boot it.
Then when I got back on, I edited in the 3 sources for the C5AZ-7007-A plate that I found on PV (PartsVoice.com) .. an obsolete parts search website.
I also looked on the Ford dealer parts locator: ZERO .. and rearcounter.com. This obsolete parts search website listed Carpenter only, while PV listed Haven, Don's and Carpenter.
Old Apr 11, 2017 | 08:37 AM
BRNWAXA's Avatar
BRNWAXA
Number Dummy
Thanks for your hard and talented work. I needed this information and was able the complete detail here!!!!!
Old Aug 2, 2023 | 05:28 PM
cschreier1's Avatar
cschreier1
6th Gear
Looking for c5az-7007-a.
Hello, I know this is an old thread but I hope it's ok to post here since I'm looking for the exact same part. I tried calling Don's trucks, Ford havens and Dennis carpenter without success. Dennis carpenter company claimed to have an inventory of 24 in stock but when I placed the order it turned out the inventory was wrong and it was unavailable. I can't find a used or nos part anywhere. Truck is the same 4.9l The truck needs the new part because the person we bought it from claimed to have replaced the clutch but didn't put back the spacer plate. We found that out when we had to replace the transmission few months later. It's been 2 months at the auto shop because we can't find the part. Any help to locate one new or used in good condition would be very much appreciated!
Old Aug 2, 2023 | 07:19 PM
Franklin2's Avatar
Franklin2
What state do you live in?
Old Aug 2, 2023 | 09:04 PM
cschreier1's Avatar
cschreier1
6th Gear
Upstate New York.
Old Aug 3, 2023 | 05:58 AM
Franklin2's Avatar
Franklin2
Here's a place in NY that has a 351w for parts. They may sell you the plate. 300 six, 302 and 351w are all the same. Except don't get on from a car, stick with a truck or van.
1985
Engine Assembly
Ford E150 Van CHK 2 BBL PARTS
X 85FORD $Call Trade Auto Wreckers USA-NY(Medford) Request_Quote 631-654-5172 / 631-654-5190 Request_Insurance_Quote
Old Aug 3, 2023 | 06:00 AM
Franklin2's Avatar
Franklin2
Here are two more with 300 sixes. A complete engine they may not sell you the part. But they may have a broken engine laying around.
1985
Engine Assembly
Ford Bronco Full Size
X P9061 $Call Mid Island Auto Wreckers, Inc. USA-NY(Deer-Park) Request_Quote 631-586-6599 /631-591-2469 Request_Insurance_Quote
319 1986
Engine Assembly
Ford Truck F150 TESTED RAN EXCELLANT CARB BROKE 23,268 A 00004420 $715 Central City Auto Parts, Inc. USA-NY(Central-Square) Request_Quote 1-800-752-3533 Request_Insurance_Quote
Old Aug 3, 2023 | 08:58 AM
cschreier1's Avatar
cschreier1
6th Gear
Thank you for looking into this. I see I didn't mention that it's a manual transmission, if that makes a difference. A couple of places I called did say that the 300 6 is the same engine as those and I even looked at a multi fit plate but my mechanic said that it has to be this specific one and other ones won't fit. I'll try calling the places you mentioned that should have the 300 6. So far I haven't had much luck with any salvage place that was willing to sell just the plate.
