V10 questions
Old Jul 20, 2015 | 09:00 PM
classicrat52's Avatar
classicrat52
V10 questions
I am going to look at a 2000 excursion Eddie Bauer all wheel drive v10 167000kms, I have been doing some reading and found a lot of people say the plugs blow out, is there ways to prevent this? I read that you just have to tighten your plugs every so often will this work to prevent the blow out? Any other tips or advice would be greatly appreciated thanks
Last edited by classicrat52; Jul 20, 2015 at 10:05 PM. Reason: Excursion not expedition
Old Jul 20, 2015 | 09:09 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
I didn't know the Expeditions got the V10. Engine swapped?
Old Jul 20, 2015 | 10:06 PM
classicrat52
My bad excursion sorry for the confusion
Old Jul 21, 2015 | 03:11 AM
Drunken_Unicorn
No worries
I think the plugs getting spit out were due to improperly or over tightening. I think the earlier versions had less threads for the spark plugs. On the V10 section there is some pretty good info on the plugs.
Snowseeker has been doing some work on his new(ish) v10, making new plug inserts and the like in this forum, might take a look at that too.
Old Jul 21, 2015 | 05:16 AM
NCTunanut's Avatar
NCTunanut
Broken exhaust manifold studs have been the only issue with my V10. Been a solid motor and I've worked it. Performance and economy will improve if you open it's airways. Is it the 2V or 3V or both blowing plugs?
Old Jul 21, 2015 | 06:23 AM
Tom's Avatar
Tom
Only the 2V, and more commonly the earlier ones from 2000-2001. After that they got more threads in the head which made this less common.
3V engines were never used in the Excursion, but they don't come out. Even when you want them to. But that's a separate issue.
Old Jul 21, 2015 | 08:13 AM
59CRL's Avatar
59CRL
I had a 2000, had broken exhaust studs so check for that. Spark plugs were fine. Finding one with so called low miles is almost impossible now. My 2000 had 140K. I sold it and 2 years later bought an 2004 with 139K on her. If you intend to use the 4WD I recommend to take the hubs off, apart, clean and lube them. Check the tech folder it is great. Good luck
Old Jul 21, 2015 | 02:20 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by classicrat52
...is there ways to prevent this?
Several ways.
1. Upgrade to the '03+ 2V heads that have more threads per plug hole (the '00 - '02 have 4 threads)
2. Install Timesert (or equivalent) aluminum threaded inserts in each plug hole.
3. Install spark plugs on a cold engine with proper torque (12 - 14lbs) and check twice a year to make sure they aren't coming loose.
Stewart
kystangbanger
Jan 25, 2012 11:50 AM
427 fordman
Nov 16, 2011 07:30 PM
gunthet
Mar 1, 2010 07:34 PM
stumpy2
Modular V10 (6.8l)
15
Jun 20, 2006 06:15 PM
Musicman250
Modular V10 (6.8l)
30
Mar 21, 2006 11:03 AM
