Disgusted with trucks performance
Nate, off the subject, where did you get your spyder for your IC setup? PM me if you want...
Back to the topic
Rear end is going to need attention no matter what, I pulled several large chunks out of it(between 8-12 little bits in the palm of my hand), it has been acting up for some time. I though it was the trans, but it turns out it was the LS in the rear end. Not sure of the extent of the damage, but depending on how bad, will determine which way I will go as far as the gearing.
I swapped out the diff in my Excursion for a LS and kept the axle in the truck. Heck, even left the wheels and tires on! (gotta love these full floates). It only cost me $20 for a shim kit plus the diff fluid (it was on sale. Cost $50-60 IIRC). Theres no doubt you could swap that 4.10 in there for fairly cheap, but that's not adding the cost of having someone do it for u.
Heres food for thought: a LS rebuild kit (for the friction plates) is $170 alone, and that's for the cheap ones. $250 for a good steel set. That doesn't include the installation kit to put the thing in when your done. Diffs are expensive lol
I also agree a rear end wont fix your problem though
I would think spicer stuff would be just fine.
/meth injection. This would help hold down EGTs when using straight distilled water. On the washer fluid, it only added to the high EGT problem. Added an intercooler and custom TW tunes. I now had plenty of power to pull the 5er, but could not use it because going uphill I was feathering the pedal to manage EGTs. Last mod session I added the new S366 turbo, bellowed up pipes, valve springs,and pushrods. As you guys know, we bought a new 5er and it weighs 9000 lbs dry weight (over 2000 lbs more than the old one). It tows it like a champ.. On the 5 plus hour trip back home from RRE, the only time I had to come out of 5th gear on a hill was coming up Flat Top Mtn on I77 in WV. I topped that mountain doing 63 mph in 4th gear with EGTs never making it to 1200.......... In my case, it seems like adding fuel and power only added to my high EGT problem. Adding the bigger turbo, which pushes more air through it did the trick. (Just my .02)
"I think we need to clarify the question here, or more specifically, understand that there are actually two questions likely being addressed:
1) what is a safe temp for the ISX
2) what is a safe temp for the lube
I don't know enough about the operational parameters set into the PCM for the ISX; someone else will have to help out here.
As for the lube, 250F is in no way unsafe. Even a conventional lube can provide a good performance if the base stock is of good quality. I believe an ideal temp would be 200-225F; most would agree about that. But a little spike in oil temp is not going to grenade the engine nor the lube. Even long sustained runs are tolerable. If you were to approach 300F in the sump, I would be concerned. But not at 250F.
And just for reference, before any of you go off half-cocked and say I'm nuts, I'll offer this bit of information ...
In the infamous GM filter study (881825), they ran the DD-60 engines at full load, with the sump at 250F for the entire duration of all the tests. Eight hours at a time. Repeated several times. On conventional lube from 1988.
And while we also would agree that massive oxidation insolubles are a bad thing, I'll remind you all that some amount of high-heat oxidation is actually a good thing, because it promotes the TCB (tribo chemical boundary layer) formation on the part wear surfaces. Or have you all forgot about SAE 2007-01-4133? This anti-wear layer of oxidation byproduct is actually a good thing, and is bolstered by higher heat. Once it is established, wear rates typically drop precipitously by and order of magnitude to near-zero levels (a direct quote from the study).
Several years ago, I flogged my Dmax pulling our RV through the Rockies and into the desert southwest for summer vacation. I let the sump get as low as I could tolerate on the dipstick. I ran that engine with no mercy in regard to throttle; if I wanted to move, I floored it, at times for minutes on end in uphill pulls out of the valley floors and over ranges. I am sure the turbo temps got hot; the EGT was maxed at OEM limits around 1300F countless times on the trip. And when I got back, and pulled the UOA, everything was completely normal; totally within specs for both the wear metals and the lube conditions. All on dino 10w-30 Rotella TP.
Is there a reason to fear lube degradation? Sure. But not at 250F."
Hope it helps regarding those of us who worry about oil temps
