Burnt up ground wire!
Old Jul 26, 2015 | 02:26 PM
Bazookajoe's Avatar
Bazookajoe
The previous owner definitely did a lot of his own custom work and swapped alot out I was told, I'm still getting to know my way around this engine and will definitely investigate to find out more were the factory location is in case the problem continues ..
Old Jul 26, 2015 | 02:30 PM
Franklin2's Avatar
Franklin2
It's way down low on the pass side front corner of the block. Pretty much where you have your grounds now, only way underneath.
Old Jul 26, 2015 | 02:35 PM
Tedster9's Avatar
Tedster9
Grounds are nothing to mess with, or ignore. The problems are not always immediately obvious either, as in the green wire here. Current can be drawn through gearboxes, wheel bearings, radiators, and throttle cables and cause all kinds of $$$ issues.
Old Jul 27, 2015 | 08:35 AM
ctubutis's Avatar
ctubutis
Yeah... those battery cables being connected to the alternator bracket like that is a sub-optimal configuration... too many possible points of failure, and you need to rely on the corrosion between the bolt (holding the alternator in) and block not getting bad enough to cause problems... battery cables directly to the block is much preferred...
Nathan Kiolbassa
Apr 29, 2016 02:49 PM
American Thunder
1978 - 1996 Big Bronco
Sep 16, 2010 07:59 PM
Prozon
16
Jan 12, 2010 11:16 PM
red89F150
Electrical Systems/Wiring
Feb 14, 2006 10:33 PM
