Positive Ground on 77? HELP!
Old Apr 28, 2016 | 10:55 PM
Nathan Kiolbassa's Avatar
Nathan Kiolbassa
Zzzzzzzzzzz
Old Apr 29, 2016 | 05:35 AM
Blue and White's Avatar
Blue and White
In general positive ground systems went out of production in the 1950's. All dents were made with negative ground... like new cars today. No dent would have been made with positive ground.
In general, a wire from the alternator to the positive side of the battery would be correct for negative ground.
Suggest you start with a volt meter and test the battery first to establish + and - polarity then start checking from there. Any energized power supply wire should show about +12 volts measured against a clean chassis ground or the negative post of the battery.
Old Apr 29, 2016 | 09:07 AM
Nathan Kiolbassa
That's the thing, when i connected the hot wire from the amplifier to the negative battery and it powered up. Someone definitely converted this and I'm kind of in pickle as how to undo do it.
Old Apr 29, 2016 | 12:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
6V positive ground: 1955 and earlier / 12V negative ground: 1956 thru today.
Old Apr 29, 2016 | 01:33 PM
jas88's Avatar
jas88
The first thing I would do is check polarity on the battery with a volt meter.
Old Apr 29, 2016 | 01:55 PM
J ballan's Avatar
J ballan
I've been told a if a normal 12v battery gets dead enough it's possible to charge it back up with reverse polarity although it never seen it. This would explain your current set up.
Old Apr 29, 2016 | 02:49 PM
hasteranger's Avatar
hasteranger
I'd check the ignition. It won't work with polarity reversed. If its not reversed there, then it's not reversed.
Bazookajoe
18
Jul 27, 2015 08:35 AM
old broke prospector
Apr 9, 2013 07:43 AM
james G. phillips
Jul 17, 2008 05:16 PM
oft
Electrical Systems/Wiring
21
Mar 13, 2007 12:43 AM
red89F150
Feb 14, 2006 10:33 PM
