Towing with turbo master wastegate
#46
#47
Well -Another update - Have tried adjusting the turbomaster 3 times & it works great when not pulling or towing, but when I pull long/steep hills towing the 5er -it keeps overboosting & defueling. I've got the nut backed almost all the way out(about 2-3 threads left). Called Dieselsite & he said to install an overboost fooler. Anybody else had this problem. I can manually back off on the gas to keep it from overboosting but that was one of the reasons I bought the TM- Because it is adjustable. Any help here appreciated. Thanks, Bill
#48
#49
#50
#52
I'm not sure about the adjust ability either. I would have expected to be able to hold the boost at ~25psi If I want to and that's not happening and, there isn't any more adjustment left to lighten the spring pressure. I guess, as long as there is not a sustained 30+psi, the turbo will be Ok and the RR Map regulator keeps the power going.
#53
Also, have you run a leak detector check? Any air out the CCV tube?
#55
#56
Same. Would like keep the boost to 25psi for the sake of the stock turbo. I would love to see 25psi as early as possible and it just stay there. With the new tunes, it's easily exceeding 25psi with no load. As I haven't towed with the new tunes yet, my concern is exceeding 30psi and then needing to back off the throttle or change to a stock tune to stay within 25psi. All this is with the understanding stock turbo even with the 360 bearing should be limited under 30psi to survive-I could be wrong but it's what I've read.
#57
#58
He brings up a good point though. He should be capable of regulating the boost level as he sees fit by using the adjustment on the TM.
Installing the boost fooler is not going to bring the boost level down as he wants to do in order to keep it at or below ~25. He is comfortable with a certain amount of boost and it seems that the TM wastegate should be able to provide him the appropriate level of boost that he is comfortable with without over boosting causing defueling and possible damage at prolonged periods.
As I understand it, he could simply have not bought the TM wastegate and just capped off the red line and would be getting the same results which is more boost and so much at times the truck is pulling fuel.
#59
#60
That's what I was saying - The whole point was the adjustability of the TM for me while towing - I did not want to have to buy something else to keep my boost below the 23-24 defuel point, which leads me to believe that the adjustment spring or something is not right or they had a defective batch of these. I didn't want to make 30 #s of boost & have to fool the pcm with another gizmo. Just saying. The part doesn't work as advertised. Wonder about cutting off a little length of the spring coil might help. I'm gonna call them Monday & see about this as an option.
I have been a customer of Diesel Site in more than a couple of occasions. Although the first products were great and as described, I have found the latest to be not what was described on the site. I had been in contact with technical support and they offered some advice, but the issue was not resolved. I chalked it up to "oh well, ****** happens" because the cost to return the now used product would be about the original cost.
I still plan to be a customer of Diesel Site in the future, but will certainly do more research from here on out first.
Keep us posted on what you find out and are told.
