Towing with turbo master wastegate
Hey all- Anybody notice any pros or cons when towing with the turbo master wastegate. I have stock tuning & can get about 15-16 lbs. boost. With the red hose to old stock wastegate removed & plugged I can get about 22 lbs. These numbers are not towing. Sure has a lot more power & quicker spoolup. So I am thinking about replacing with TM.- Will this affect my pyro temps adversely when towing? Appreciate any comments.
I don't really think the TM wastegate would really be worth the money if you're running stock injectors and tuning. (I don't see anything about injectors in your sig) I have the TM wastegate and I can keep my EGT's around the 7-800 range running around 25 PSI with stage II injectors while towing. The most I've hit towing was 1000 degrees.
Well, with the TM you'll get the boost you saw with the red line removed and still have the waste gate function when you snap the throttle closed. As to EGT effect, I don't know. Hopefully someone chimes in with this info. I'm in the same situation and would like to know.
Originally Posted by greg_8507
(Post 15515534)
...I have the TM wastegate and I can keep my EGT's around the 7-800 range running around 25 PSI with stage II injectors while towing. The most I've hit towing was 1000 degrees.
Originally Posted by guitarpicr
(Post 15514781)
Edit: heck it might actually turn out to be better since it is more precise than the stock canister design and won't allow the wastegate to open early and loose that mid range performance.
Thanks guys- I guess its better to have the TM in there than to just leave the redline plugged ?
(Post 15516635)
But without a chip/tuner your gonna max out at 22 anyway. |
Originally Posted by Tugly
(Post 15516008)
Where is your EGT sensor located?
Well I got a TM on order - I'll post back after its in & I tow to let you know how she does. Might be a couple weeks b4 I tow with it. I would be very happy with 22 max boost. Thanks again for all the help.
Sweet! Make sure to update the thread in the fall!:-X22
Originally Posted by white Buffalo
(Post 15516244)
I am very pleased with the TM when towing !!
(Post 15516635)
The Turbo Master is more like a dump valve than a waste gate due it's design. But the factory w.g. is more refined of a system and puts less stress on the turbo shaft. I have found in my research from measuring the turbo shafts on turbos that ran a T.M. set at 25-30psi that there was more wear and more stress on the shaft compared to a stock w.g. set up. Like it was said earlier just don't push a stock GTP38 because at 25psi and higher you asking too much out of the poor stock turbo. |
How did you guys come to setting your TM spring tension? Do you see any different boost daily driving vs. Towing?
Originally Posted by BadDogKuzz
(Post 15519083)
That is exactly what I found to be the benefit of running the TM w.g. over the stock w.g. was GREAT mid range performance. The TM does not dump the boost running down the highway when towing and you come up on a slower car and then having to put your foot back into it. With the stock w.g. with red line off the spring in the canister wasn't strong enough to keep from bleeding off boost.
I am very pleased with the TM when towing !! Good to hear Bad dog - Cant wait to get it & tow with it now. Oh I am running stock injectors (AB) and stock tunes with a 1.0 turbine, WW and TM and when towing I can get 22psi with 10k behind truck. With my boat 8.5k I get 20psi and driving at highway speeds it is a major improvement over stock. I have mine set to start to open about 21-23psi. The Turbo Master is more like a dump valve than a waste gate due it's design. But the factory w.g. is more refined of a system and puts less stress on the turbo shaft. I have found in my research from measuring the turbo shafts on turbos that ran a T.M. set at 25-30psi that there was more wear and more stress on the shaft compared to a stock w.g. set up. Like it was said earlier just don't push a stock GTP38 because at 25psi and higher you asking too much out of the poor stock turbo. |
Originally Posted by DND58
(Post 15519516)
