Each one has its perks and downsides... I prefer the overall design of the TC with the higher clearance lower side pieces, but I dislike the inward angle on the grill guard. The RH is more business but I'm not a fan of how low it hangs, although overall it sits the same as a stock bumper... The major downside to both of them is you loose the stock towhooks which are quite beefy, and neither bumper has provisions for me to mount my rear hook up front.
I got my grill guard because I couldn't find anything else that I liked and now these two options are looking me in the face, lol.
This has been added to the first post, but I figure I'll post it as a stand alone too...
Moderators Edit: We'll see if this works on a temporary trial basis. I can understand wanting to help each other out and alerting people to good deals, but most items on CL will be strictly regional, and it may be too tempting for people to list their own CL ad which is against FTE Guidelines.
If you are tempted to post your own CL ad, please don't. If you post a CL ad and you see later it's missing, it was a discretionary call. Don't question why in an open thread because that too is against FTE Guidelines. You can PM one of the Excursion Mods and ask though.
This thread is rife with many pitfalls and problems that can get users in a lot of trouble, and I'm not convinced it will work smoothly, so let's all try to make it work together.
Son of a ...... I feel like an idiot. Been using J bend pins
If you like them over the barbell straight pin, just add a small hose clamp to the "J" end of the pin to keep the bend of the pin from wallowing or ovaling the hole out.
So basically, add this...
...to the bent elbow part of a pin like this....
....or just buy a barbell straight pin like this...
