A/c problems help!
Old Jul 19, 2015 | 12:03 PM
Geary's Avatar
Geary
A/c problems help!
So I've had leaks fixed, low press sensor replaced, fuses check out, clutch coil replaced and still have gotten nowhere. I have 12v of power at the clutch connector unplugged, but when I pick the wire while it's plugged up and turn the system on, the 12v disapeares. I've jumped the clutch directly to battery and it does operate and blows plenty of cold air. Why do I lose voltage when the connector is connected??? Thanks in advance
Old Jul 19, 2015 | 12:09 PM
JWC 3's Avatar
JWC 3
What year is your truck ?
Old Jul 19, 2015 | 12:11 PM
Geary's Avatar
Geary
95 f150 5.0 107,xxx mi
Old Jul 19, 2015 | 12:29 PM
JWC 3's Avatar
JWC 3
You are dropping voltage ... Sounds like a wiring or connector issue .
Check for corroded connections and check for damaged wiring .
Old Jul 19, 2015 | 02:37 PM
Geary's Avatar
Geary
it would be super helpful to have a wiring schematic. where do i get such thing?
Old Jul 20, 2015 | 09:08 AM
rla2005's Avatar
rla2005
Here:
The disappearing 12V is caused by an open circuit, it's a phantom voltage that your high impedance meter is displaying.
Old Jul 30, 2015 | 08:37 AM
WoodBoss's Avatar
WoodBoss
Check to see if you have voltage before and after the ac cycling pressure switch, if you don't work your way back.
granny_rocket
Jul 14, 2014 07:42 AM
bryanj
Mar 22, 2010 10:40 PM
Bear River
Aerostar
Feb 18, 2009 05:12 PM
jp1956
Aerostar
Apr 8, 2007 10:16 PM
Glenn Townsend
Aug 12, 2004 01:47 AM
