Zf behind a 302.
Old Jul 18, 2015 | 11:54 PM
John_0063's Avatar
John_0063
Zf behind a 302.
Hey there I'm looking to put a zf 5 speed in my 88 F-150 4x4 with a 302. It has the m5od right now. I have a 90 F-250 4x4 with a 7.3 as the donor truck. Now I know the bellhousing is different but will the bellhousing off a 4 speed out of an 87 F-150 bolt onto the zf gearbox? Or do I need to find a bellhousing from a small block zf? And will the input shaft on the diesel zf work with a 302 clutch? Thanks in advance for your insight.
Old Jul 19, 2015 | 06:47 AM
EPNCSU2006's Avatar
EPNCSU2006
The bell housing on the ZF is integral with the case. You need a ZF from a truck with the 300 six or 351w. The input shaft will then match the 302 clutch as well.
Old Jul 20, 2015 | 09:28 PM
John_0063's Avatar
John_0063
So it is... I guess I should've taken a better look at it. Thanks for thd reply.
Old Nov 30, 2016 | 10:25 AM
billyboyr6's Avatar
billyboyr6
id be interested in the 7.3 bellhousing if you dont have a need for it.
Missin'A Gear
15
Dec 30, 2015 07:38 AM
hawkmaneg
Nov 21, 2007 10:11 PM
Dean88
Nov 12, 2007 04:28 PM
95bronc5spd
Jun 13, 2007 09:06 PM
i8ahorse
Oct 26, 2000 10:50 AM
