Vin # info
Old Jul 18, 2015 | 07:13 PM
Hickishway's Avatar
Hickishway
Vin # info
Hey, so I have been trying to find info on our new project and can't seem to find too much. I was hoping someone here could help me. We wanted to see how rare it was before we decide which route to take with it.
VIN # F25AC872190
DSO # 420322
Anyone able to help out?? We were told it was a 65 but appears to be a 66? Thanks!!
Old Jul 18, 2015 | 10:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN: F25AC872190 / DSO: 420322
Welcome to FTE
None of these trucks (1961/66) are considered "rare."
F25 = F250 2WD
A = 240 1V I-6.
C = Oakville Ontario Canada Truck Assembly Plant.
872190 = 1966, assembled June 1966.
42 = Fargo ND Ford District Sales Office, where the original selling dealer ordered the truck from.
0322 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
6,699 Flareside & 58,489 Styleside 1966 F250 2WD pickups were assembled.
Old Jul 19, 2015 | 09:42 AM
Hickishway's Avatar
Hickishway
Welcome to FTE
F25 = F250 2WD
A = 240 1V I-6.
Thank you! That's def very helpful. We have the frame for it as well just no engine, bed, hood, missing a fender and grill. We were debating ripping the cab off the frame and putting it on something else but don't want to if its a limited thing.
Old Jul 19, 2015 | 10:54 AM
Hickishway's Avatar
Hickishway
Oh, and I don't know if there is a way to find out about the fact it's a 4-door not 2-door which was even more less common.
Old Jul 19, 2015 | 11:02 AM
Hickishway's Avatar
Hickishway
Pictures of the new beast
Old Jul 19, 2015 | 11:20 AM
NumberDummy
You failed to mention that your truck is a Crew Cab. I wondered how in the hell your truck could be ordered from Fargo ND then assembled in Canada, because...
Thru December 1967, all Ford and Mercury trucks assembled in Canada were only sold new in Canada, with one exception: Crew Cabs.
This is a mid 1965 Ford factory assembled Crew Cab. The early 1965 Crews were modified from Regular Cabs by Crown Coach, have exposed rear door hinges, different shaped rear door window frames.
There are no production figures available as all (1965/72) Crew Cabs were converted from Regular Cabs (Warranty Plate BODY code: 81 = F Series Conventional Cab).
There are no specific to Crew Cab parts listed in the 1964/72 Ford Truck Parts Catalog, as all were Domestic Special Orders.
In order to get specific Crew Cab parts, dealers had to contact FoMoCo with the 6 digit DSO code. FoMoCo would look up the DSO number, give the dealer the part numbers.
1965/66's may have used the 1957/60 Styleside beds, called the "wrong" beds by enthusuasts, as the bed lines don't match the cab lines.
Ford cut these beds off just in front of the wheel opening, then welded the front bed panel on. They look horribly amateurish, like a shade tree mechanic would have done.
Some 1965/66 Crew Cabs also used the 1964/66 F100/250 2WD & 1966 F100 4WD Styleside beds.
Most 1965/66 Crew Cabs, all 1967/79 Crew Cabs were assembled at the Oakville Ontario Canada truck plant.
Old Jul 19, 2015 | 11:57 AM
NumberDummy
F25 = F250 2WD
A = 240 1V I-6.
C = Oakville Ontario Truck Assembly Plant.
135" Wheelbase.
J = Rangoon Red.
F250 2WD .. 5,800 lbs. GVWR
81 = F Series Conventional Cab, minus the first digit of the BODY code that pertains to the type/color of seat upholstery, 81 BODY code without the first digit specific to Crew Cabs only.
F = Borg-Warner T-18 4 Speed Manual Transmission.
24 = Spicer/Dana 60 Rear Axle / 4.10-1 / 5,200 lbs. Rear Axle Capacity.
5,200 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
420332 = Info already decoded.
Old Jul 19, 2015 | 12:34 PM
Rbeck204's Avatar
Rbeck204
Nice crew cab
Good start on a rare truck. I have an F100 1965 Crew Cab.
Good luck with the build.
Old Jul 19, 2015 | 08:11 PM
Hickishway's Avatar
Hickishway
That thing is awesome! Good luck to you as well
Old Jul 20, 2015 | 04:37 AM
Crop Duster's Avatar
Crop Duster
VIN # F25AC872190
DSO # 420322
That is one really cool truck, the patina is perfect and you've got both back doors.
Old Jul 20, 2015 | 06:21 AM
fordpt's Avatar
fordpt
4 door is rare. Cab mounts look solid, how are the floors?
More pictures please.
Old Jul 20, 2015 | 11:25 AM
NumberDummy
This is an early 1965 Crew Cab that was probably assembled by Crown Coach.
Notice it has exposed rear door hinges and that the rear door window frames are a different shape than the FoMoCo assembled Crew Cab pictured in post 5.
Old Jul 20, 2015 | 12:58 PM
Hickishway's Avatar
Hickishway
The drivers side and passenger floor at the toe has some holes that need replacing. Otherwise it's solid.
This was a junkyard find that my fiancé just couldn't pass by. It has been sitting in the same spot since 1989.
Old Jul 21, 2015 | 10:17 PM
BarnieTrk's Avatar
BarnieTrk
VERY NICE, INDEED!
BarnieTrk
73 Crew
Feb 24, 2017 12:25 PM
collin238x
Sep 9, 2013 04:13 PM
Irish19614x4
20
May 19, 2013 09:03 PM
Unclejon
47
Sep 1, 2012 02:20 PM
MYF250GH
Jan 27, 2008 03:25 PM
