Ol' Orange Won't Start
Old Jul 18, 2015 | 09:06 AM
Caleb H's Avatar
Caleb H
Alright, went to go to the scrapyard today with a load of metal I've been slowly accruing in the bed of my '83. The truck been sitting for about three weeks. I went to start it, and it cranked no problem like usual, but didn't turn over (like usual after sitting). Cranked again after pressing the pedal, still wouldn't turn over, although that is still normal for my truck. Went to crank again.... CLUNK. That's all it does now when the key is turned to start. It's like a cross between a click and a clunk.
I'm thinking either the starter finally gave up the ghost or the solenoid is bad, but I'm not positive on how to investigate it. How would I go about figuring out which is my problem? I guess I could replace both but why bother taking out a good original part if one of them still works?
Maybe it's fate... at this point I feel as if I'm doomed never to unload that metal
Old Jul 18, 2015 | 10:04 AM
Don Naslund's Avatar
Don Naslund
Could be that the bendix got jammed up. Try to turn the engine by hand about 1/4 turn tehn try the starter.
Old Jul 18, 2015 | 10:11 AM
stuart1's Avatar
stuart1
Um?
Cranked but wouldn't turn over?
Old Jul 18, 2015 | 11:27 AM
Caleb H's Avatar
Caleb H
Yeah, but like I said, that's typical for my truck. If I leave it sit for a few weeks it takes a little bit of work (usually less than 15 seconds all told) to get it started. That wasn't my problem, though; the truck does not crank at all now. It just makes a single noise like a click or a clunk.
Old Jul 20, 2015 | 01:57 PM
1986F150six's Avatar
1986F150six
Place a wrench on the bolt holding the harmonic balance to the crankshaft and see if the engine can be rotated by hand.
Old Jul 20, 2015 | 01:59 PM
Franklin2's Avatar
Franklin2
You can rule out the solenoid by taking a set of jumper cables, hook one of the red clamps to the battery +, and touch the other red clamp to the large lug on the solenoid that goes down to the starter. MAKE SURE YOU ARE IN PARK OR NEUTRAL BEFORE DOING THIS.
Old Jul 20, 2015 | 02:15 PM
ctubutis's Avatar
ctubutis
Battery needs charging?
BTW "crank" and "turn over" mean the same thing, is that what you're trying to say? You turn the key to START but the starter motor fails to crank/turn over the engine?
Old Jul 21, 2015 | 07:40 AM
InfantryCPT's Avatar
InfantryCPT
X2 if battery is in poor condition or wont hold a charge, get a new one, if you can afford it get one with higher cranking amps.
paddler
Dec 18, 2010 06:41 PM
69ranger250
13
Jan 28, 2009 12:17 PM
cag1980
Sep 29, 2008 09:12 AM
greg240
Apr 19, 2004 05:37 PM
87carbed
Nov 2, 2003 07:05 PM
