A/C system replacement
Old Jul 19, 2015 | 10:24 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
First off I decided to replace the entire system due to the labor cost for A/C work. I figured I could replace the system cheaper that having the compressor replace by a shop. That was my mind set so that's what I did. I also decided to go through the front just for easy access. I know those that do this work for a living would say that is insane, but it’s just a little extra time to get right at it. Besides, working to some Merle Haggard and George Jones will make for a good day…
I am going off of memory, so don’t be too harsh on me. J
Removing the compressor –
· Bumper – 4 bolts in the front, one on each side on the support bracket.
· Grille – 4 screws on top and 4 clips at the bottom.
· Head lights, 4 screws each
· Grille support 4 bolts on each side.
· Condenser – 2 brackets and 4 bolts.
· Intercooler – both intercooler pipes removed
· Transmission cooler – 4 brackets and 4 bolts
· PS cooler – 2 brackets and 2 bolts
· Radiator support 8 bolts
· Radiator – 2 brackets 4 bolts. Transmission lines (requires a special tool) reference the one Rusty posted. Upper and Lower radiator hoses.
· Radiator shroud.
· Stator – 4 bolts with an impact.
· Fan nut - Borrowed brothers fan wrench
· Lock belt tensioner and remove belt.
· Remove tensioner – 2 bolts
· Remove starter cable bracket – 1 nut and the bolt
· A/C Compressor has 1 connector, and 3 bolts. The 2 front bolts are 10mm and the bottom rear bolt is a 13mm. Ratchet wrenches make removing the compressor a breeze!!
· High pressure switch –
Evacuator and dryer –
· Remove the orfice tube connection using an A/C fuel line disconnect tool.
· Unbolt the dryer from the evacuator
· Remove the dryer by removing 3 screws.
· Remove the oil fill tube.
· Remove the nut holding the transmission dip stick and move the dip stick aside.
· Remove aluminum heat shield. Kind of a pain due to the lack of room. I have baseball mitts for hand so this wasn’t fun.
· There are approximately 8-10 screws that will need to be remove from the top and right side of the HVAC box. I used a an air ratchet with long extensions for the rear.
· Remove the evaporator cover
· Remove the evaporator.
· At this point your are done removing “stuff”. Gingerly start putting everything back together. Take your time to fit everything together without damaging orings!!
Other things I did to while in there:
· Remove the starter and installed Fomoto valves on the block.
· Flushed cooling system and installed a new Motorcraft thermostat.
· New upper and lower radiator hoses
· New drive belt
Old Jul 19, 2015 | 10:26 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Originally Posted by 2005 Ex Limited
Get your money back on your UV flashlight then. Here's what mine looked like.
Kinda relieving to see it right away, but hurray for being the single most expensive piece of the system, and not just a connector.
Nah, the wife uses them to drive at night!
I wish my leak showed up like that. I am wondering if the compressor was leaking behind the clutch??? What I can tell is there was PLENTY of dye in the system that it should have shown up.
Old Jul 19, 2015 | 10:28 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Oh and a couple of obvious things I misses was removing the MAP bracket and HVAC support bracket on top. Those fire wall bolts were LONG winded... Just sayin!
Old Jul 20, 2015 | 07:58 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
No complaints here!!
Old Jul 20, 2015 | 08:25 AM
WatsonR's Avatar
WatsonR
I did the same thing you did thru the fender.... almost wished I went this way, much room to work and you got a couple extra things done while there... nice job!
If you could estimate the time to remove the front to get down to "the work", please?
Old Jul 20, 2015 | 08:51 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I helped my brother rebuild and replace his 6.0 so I've done this before so I had some previous experience. That being said, 1.5-2 hours for 1 person and 45min-1 hour for 2 people. It's just time, none of it is hard, and I would rather take a little extra time to make the job easier.
Old Jul 20, 2015 | 01:53 PM
69cj's Avatar
69cj
That orifice tube looks like you were growing weed in it. lol
Old Jul 20, 2015 | 02:20 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I have no idea what you are talking about!!
Old Jul 21, 2015 | 06:32 PM
2005 Ex Limited's Avatar
2005 Ex Limited
And that's what I was saying. That much oil has to go somewhere. I was stoked to see it work.
Hotrod350
18
Jun 3, 2018 10:48 AM
Twonky
Sep 22, 2017 07:52 PM
0500757Arf
Aug 19, 2016 10:15 AM
nmlewis
Dec 7, 2014 12:04 AM
davewave649
Oct 7, 2012 02:40 PM
