Bizarre Fuel Leak
Old Jul 17, 2015 | 08:28 PM
kemamo's Avatar
kemamo
From what I've seen no. This is only from looking at it with the intake manifold on top still attached. I can take it off for a better look but I'm pretty sure it's not leaking from the top
Old Jul 17, 2015 | 09:17 PM
bigb56's Avatar
bigb56
It's got to be a pinhole in the pass side fuel line spraying onto the places you're seeing wet.
Old Jul 18, 2015 | 06:58 AM
Tugly's Avatar
Tugly
1. You need a clean and dry valley to start with.
It's a pain, but once you have a clean surface in there, you can spot a leak source right away. I strongly suspect the fuel line clamp near the turbo pedestal has worn through the fuel line. bigb56 and Bonanza35 mentioned the likely source, and clem1226 mentioned a good test - once the valley is dry.
Old Jul 24, 2015 | 11:39 AM
20007.3f250's Avatar
20007.3f250
refer to one of my post , I only have a few. The passenger side fuel line is surely it. Mine was a pin hole at first, once I added some power to the motor the pin hole became a crack. Most surely is it. With the truck off you can put little pressure on the line by moving it with your hands and hear the air releasing from the line . Thats how I know it was the fuel line, the bracket rubbed a hole right through it
f350xlt460
Feb 19, 2023 08:41 AM
Budlight7
Apr 10, 2014 03:42 PM
glasseater
Nov 4, 2013 09:41 PM
bill1954
31
Jul 26, 2012 06:54 PM
phoenix44
Oct 1, 2009 11:40 AM
