fuel leak
Old Sep 29, 2009 | 06:41 PM
phoenix44's Avatar
phoenix44
fuel leak
I got a fuel leak that appears to be coming from where the line that runs from the drivers side fuel rail to the fitting that is connected by the banjo bolt. It actually appears to be coming from the line where it runs into the fitting. I guess I need to replace the lines to both sides with the fitting that is connected by the banjo bolt. Any help would be appreciated.
Old Oct 1, 2009 | 11:40 AM
phoenix44's Avatar
phoenix44
Finally got it fixed. Had to replace the fuel pump at the same time because it was starting to leak.
