F1 steering
Old 07-13-2015, 03:25 PM
olguy317's Avatar
olguy317
olguy317 is offline
F1 steering
Hi guys,
I just replaced the steering box, drag link ends, tie rod ends and kingpins on my '50 F1. I took it to a shop and verified that the toe-in was within specs. I have new wheels and new radial tires....and the darn thing goes wherever the wave in the road wants it to. I installed a dropped axle as well if that plays into anything. Can someone tell this oldtimer why the truck won't go straight down the road? Every time I cross a wave in the road it wants to wander. I understand that this style of steering setup is prone to bump steer but this thing is unsafe! I have a '27 T bucket with the same type steering and it's fine. What am I missing? Should I scrap the mess and go for an IFS?
Thanks for any advice.
Tony
(olguy)
Old 07-13-2015, 03:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Did they measure your caster at the alignment shop? I'm guessing you don't have enough.
Old 07-13-2015, 04:27 PM
olguy317's Avatar
olguy317
olguy317 is offline
No they didn't measure caster, but I installed wedges when I replaced the stock axle with a 4" dropped beam. I think the wedges were supposed to supply 7 degrees of caster. I installed the thick part of the wedge to the rear, which should have tipped the axle back. Was that wrong?
Old 07-13-2015, 09:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's the correct way to increase caster. Are your U-bolts tight? Have you checked that the wedges are still in the correct place?
What toe-in did they set it to? Should be just barely toed-in (1/16" or so).
Old 07-13-2015, 09:41 PM
my 66's Avatar
my 66
my 66 is offline
I have never worked on your model truck so just asking could the spindle have been swaped around. like I said just asking.
Old 07-13-2015, 11:41 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Are your spring eye bushings/pins nice and tight? I just replaced mine....drives a lot nicer!
Old 07-14-2015, 11:55 AM
olguy317's Avatar
olguy317
olguy317 is offline
Thanks guys,
The spring hardware is all new and tight. I'm beginning to suspect the newly rebuilt box I got from Rock Auto's supplier. The box was tagged "do not adjust", and it didn't seem to have any slop on the bench, but now with the tires on the ground, I'm feeling about 3" of free play at the stock (large} steering wheel. I have to get under the truck and have the wife rock the wheel to see if the pitman arm moves.
Old 07-18-2015, 11:57 AM
jonf's Avatar
jonf
jonf is offline
You installed the wedges backwards. the thick part goes to the front to tilt the axle back.
Old 07-18-2015, 12:16 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,468 Likes on 1,408 Posts
Old 07-20-2015, 12:36 PM
olguy317's Avatar
olguy317
olguy317 is offline
Thanks again to all who responded. I found an alignment shop in the area that can do an alignment. Going in Tuesday. Young feller says toe adjustment will produce the lane-jumper problem that I have. We'll see Tues. P.M.....sure hope he's right. My thoughts about the steering box free play was shot down by a rep from Lares. He said about 2" of free play with a stock 18" wheel is about as tight as you can adjust the box....
Old 07-20-2015, 05:46 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
Im going to guess that there is too much toe-out.
If you can get a picture of the alignment screen before and after we can help rule out any other issues
Old 07-20-2015, 07:06 PM
Nicholas+'s Avatar
Nicholas+
Nicholas+ is offline
Good luck with it!
You know how when you take a turn and are ready to straighten out and you loosen the grip on the wheel and let it "slide" through your grip to go straight again? Does that happen or do you feel like you have to steer it back straight? If that's the case, I think it might not be enough positive caster. Of course it could be lots of things, but the more caster you have the more the vehicle will want to go straight without any input from you. To much and the steering can feel heavy or un responsive.
I used to do alignments when I worked at the ford store as a kid. It been a while though lol.
Old 07-27-2015, 08:33 PM
MC351's Avatar
MC351
MC351 is offline
Any progress?
Did the alignment fix the problem?
Old 08-01-2015, 12:07 PM
olguy317's Avatar
olguy317
olguy317 is offline
F1 steering
As yet the problem is not solved...I've had the truck aligned. Results showed about 2 degrees caster per side..I installed 6 degree wedges when I installed the axle, but I have a pretty heavy rake so I guess that lessens the caster. I'm going to install wedges to try to bring it up to 4 degrees if I can find the wedges. Also, Sid suggested that it could be bump steer, and to jump on the front bumper and see if the steering wheel moves...it does indeed!
Okay so now I look at the pitman arm/drag link relationship and find it's less than 90 degrees.. have to heat and bend the spindle arm to try to bring that closer to 90 degrees. Where is the pitman arm supposed to point at straight-ahead?
I thought someone said it should be nearly vertical..the ball on mine is about
1 1/2" toward the rear of the truck. Does that matter? If this sounds like I'm baffled, it's only because I am. I'm sure there's a solution, but I can't seem to find it!!!
Thanks for all your suggestions guys,
Olguy317 (Tony)
Old 08-01-2015, 12:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Mine is really close to vertical. That sounds like more bending than should be required.
cobraman44
10-26-2018 12:40 PM
Martin Torres
04-04-2018 09:48 AM
Grumpyolddog
35
06-17-2017 10:29 AM
mbarrad
15
04-07-2012 11:17 PM
BillyL
06-28-2006 11:20 PM
Quick Reply: F1 steering
