Battery change
Old Feb 27, 2017 | 11:30 PM
trudiesdad's Avatar
trudiesdad
Battery change
It started about 2 months ago, my door ajar light and dome light would come on at times when driving. Saturday morning I went out to start it and battery was dead, tried to jump it over, but it wouldn't even turn over. Purchased new battery, started fine but gauges don't work, power windows don't work, no inside lights work, radio won't work, and all lights on instrument panel stay lit when started. Checked fuses inside and outside. Any ideas????? 2004 Excursion Diesel
Old Feb 28, 2017 | 07:44 AM
projectSHO89's Avatar
projectSHO89
The intermittent door ajar/dome lights is probably due to an intermittent door/window latch switch, you have 6 of them in an Excursion. Very common for them to get intermittent.
Has it been raining a lot recently, particularly immediately prior to the battery going dead?
Old Feb 28, 2017 | 02:37 PM
Quinner30's Avatar
Quinner30
Multiple electrical gremlins, I always suspect a bad ground.
Old Feb 28, 2017 | 05:30 PM
projectSHO89
Bad grounds can be a PITA, but it's unlikely that's the case in this vehicle.
Old Feb 28, 2017 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
I would try a do- over. Disconnect the battery + cable, turn on the headlights to kill any residual, wait a minute, then reconnect the + cable....... make sure both cable clamps are tight.
Old Mar 1, 2017 | 08:08 AM
projectSHO89
WHOA!!!
Never disconnect the + cable first, use the NEGATIVE cable for the first disconnection and the last connection. This is a SAFETY issue.
trudiesdad
Feb 27, 2017 11:23 PM
willpoole
Oct 11, 2016 05:20 PM
aquasport17
Jul 8, 2014 08:46 AM
VRC9170
Jan 5, 2013 06:21 PM
papashaun
1997 - 2003 F150
Nov 15, 2009 02:08 PM
