Engine Swap Crossmember
Old Jul 13, 2015 | 12:15 PM
Byrd.Dog's Avatar
Byrd.Dog
Does anyone know of a bolt-on frame crossmember with motor mounts for the 335 series engines? I have seen them for 351W's and actually ordered one for a big block hoping it might fit with slight modification, but would rather return it & buy something that fits perfectly rather than turn it into a hack job.
Old Jul 14, 2015 | 07:33 AM
Gary Lewis's Avatar
Gary Lewis
It might help if we knew what truck you are talking about. Surely it isn't the '60 with only 16,000 miles?
Old Jul 15, 2015 | 03:48 PM
Byrd.Dog's Avatar
Byrd.Dog
That's the one. It's low miles, but most of them were in dirt & in 4wd, so the 292 would've required a rebuild anyway. And it's not the original engine either; my dad blew the original in a snowstorm in the early 80's.
Old Jul 15, 2015 | 05:46 PM
Gary Lewis's Avatar
Gary Lewis
Sorry, I can't help as I know nothing about those trucks.
Old Jul 16, 2015 | 02:22 AM
73XAFalcon's Avatar
73XAFalcon
Check with Trans Dapt or L&L Products. If you can't find anything, start with a mount kit for a 351W as it will fit a 351C....that will get you about 50% there. The 351M/400 have the same width pan rails and use the same oil pan as the 351C so you'll be in the ball park as far as mounting location. You will need to either modify the frame mounts or custom fab motor mounts that fit the frame mounts and bolt to the 351M/400 block.
59flatbedford
Mar 13, 2006 09:41 AM
JByrd1173
Texas Chapter
Oct 22, 2004 08:43 PM
padd54
Oct 4, 2004 03:09 PM
SPOWEL4
Feb 13, 2002 09:50 PM
Boss300
Jul 31, 2001 08:29 AM
