408 Stroker over heating at breakin.
I have a 79 former 351M with Tim Meyers help is now a 408. Here is the problem: We are trying to break in the engine but after 2 min. it is up to 180 degrees and the radiator is cold so we shut it down. It has a March serpentine system that came with a new water pump. New thermostat and Eldelbrock intake. What are some possibilities as to the problem?
I agree. The bypass system on the 335 Series engines is below the thermostat, so flow of warm coolant won't heat the 'stat very much. And the correct 'stat is a 195 degree unit, so it won't open at all until you get close to that. Until then, all the flow is in the block.
The only way there isn't flow is if the water pump's vane isn't spinning. If you are sure the vane was attached to the shaft and you can see the shaft spinning then there is circulation. But you can put another temp sensor in the water jacket to ensure that's the case. IIRC there's a plug in the block in the left rear that can be used - although I can verify that later today if you want as I have two blocks on engine stands.
69taposer
08-06-2012 10:56 AM
