Does anyone know what this is called? A/C Wire
07-13-2015, 09:39 AM
Skippy's AC keeps kicking off after we kill the motor, then restart (like at a drive-thru) and if I wiggle this wire it'll start right up again. I'm thinking I need a new wire and sensor plug, but my local joint can't figure out what it's called. Does anyone have an idea?
07-13-2015, 10:17 AM
Its definitely a pressure sensor/switch. I believe that is the "high side" of the system.
07-13-2015, 10:19 AM
Reason: duplicate post due to bad internet connection
07-13-2015, 10:28 AM
Here's a couple of part#s I came up with from Rock Auto.
Airtex/Wells 1P1427 or Airtex/Wells 1P1401 ( I think this is probably the one you want).
07-13-2015, 10:33 AM
EDIT: Part numbers, even better! thank you!
Rep avalanche!
07-13-2015, 01:11 PM
That is a harness that has its issues. Does the ACC engage if you wiggle the wires?
07-13-2015, 03:45 PM
Quote:
Originally Posted by
Thomas White
Yes sir, and 9 times out of 10 it'll engage without a wiggle.
07-13-2015, 06:00 PM
on
olfordsnstone
11-08-2018 04:27 PM
d4j2s0
02-07-2018 01:02 AM
JD Q
2004 - 2008 F150
16
05-19-2017 09:56 AM
James.
Electrical Systems/Wiring
16
06-15-2014 09:16 AM
SlickWiSlick
24
10-17-2008 01:33 AM
