What wire did that rat chew??? Help
Old 04-06-2017, 07:27 AM
JD Q's Avatar
JD Q
JD Q is offline
Hello,
I have a 2004 F150 XLT w/4.6 and tow package. the truck doesn't get driven every week. Please help with identifying this wire and how to get to it.
The engine light just started flashing when driving and mostly stays on but sometimes shuts off when idling. I found some rat debris on top of the intake/valve cover. I also found a cut wire while looking up from the ground just past the #1 bank forward o2 sensor. I pulled the passenger side inner wheel fender and took a picture of the wire. It looks like a 12ga. wire with heavy insulation. I can not find the other end or where the wire goes toward the center back part of the engine at the firewall and top of bell housing.
Thank you for your time and all information is appreciated.
JD from the generation 6 f150 forum.
Old 04-07-2017, 08:55 AM
alloro's Avatar
alloro
alloro is online now
Received 4,194 Likes on 2,430 Posts
Does the wire have any power (key on or off)?
Could it run to the O2 sensor heater circuit?
Could it be trailer power?
Old 04-07-2017, 10:55 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
If it's solid black, it's a ground wire.
A single wire like that won't have anything to do with the trailer or O2 sensor circuits.
If you'd posted your fault codes, they'd probably offer additional insight into what's malfunctioning.
Old 04-07-2017, 12:11 PM
JD Q's Avatar
JD Q
JD Q is offline
I had driven it on three occasions when this stared. each time po171 occurred and once po301.
I'm just guessing.
It could be the knock sensor under the intake manifold. Where is the wire loom that feeds the sensor?
Old 04-07-2017, 12:12 PM
projectSHO89
Okay, is it or is it not a single, black wire? If so, it what I already said it is.
Old 04-07-2017, 12:16 PM
JD Q's Avatar
JD Q
JD Q is offline
I believe it is a solid black wire.
to what and from what would it be grounding?
Old 04-07-2017, 12:18 PM
JD Q's Avatar
JD Q
JD Q is offline
The wire is a small gage with heavy soft flexible insulation. I agree it is most likely a ground.
Old 04-07-2017, 12:19 PM
JD Q's Avatar
JD Q
JD Q is offline
No additional accessories have been added outside of Ford dealer
Old 04-07-2017, 01:13 PM
alloro's Avatar
alloro
Can you trace where it goes?
Old 04-07-2017, 01:24 PM
projectSHO89
Probably between the grounding stud on the firewall and the starter motor mounting bolt.
Old 04-07-2017, 01:42 PM
JD Q's Avatar
JD Q
JD Q is offline
I can barely get my hand on it. The location is at the top of the bell housing where it meets the block. I don't know what it is attached to. I will have to pull the intake to get to it.
Old 04-07-2017, 02:54 PM
projectSHO89
Neither the schematics nor the manual indicate that there is a grounding wire in that location. Check the locations I gave you before trying to dissect the beast. You may just be experiencing a slightly unrecognized routing path.
Old 04-15-2017, 03:38 PM
JD Q's Avatar
JD Q
JD Q is offline
Found more damage
I believe I found the connection. The harness conectton has a brown and a black wire to it. Please see the attached picture. I don't know what device or sensor that it goes to. All help is appreciated.
Old 04-15-2017, 03:41 PM
JD Q's Avatar
JD Q
JD Q is offline
Took this picture from the drivers side of the intake.
Old 04-22-2017, 08:17 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
Could be intake runner control
also called intake tuner valve control ,really can't tell wire colors .
Quick Reply: What wire did that rat chew??? Help
