Leaf Spring Suspension Replacement help
Both my front springs are broken due to an accident.
I read F81A AFD RPN 0779 Drivers front side
I would like to replace both of them without being overpriced at the dealer.
Maybe ebay replacement?
I did my research "google" with no success..
This is my First F250 and need your help..
Also would like to replace my Motorcraft shocks
Now has
Front ASH-12302
Rear ASH-23372
Rancho?
Bilstein?
Should I go with Drilled Slotted Rotors or Same?
Ceramic or Semi Metallic brakes?
Any help would be great.. Thank you!!!
No help with the shocks.
I bought slotted and drilled rotors with Hawk LTS pads for the front of my F-250 and they are great.
Bilsteins, I think, are overpriced for a truck application. What shock you choose needs to be matched to the intended use, as well as budget. Definitely don't buy the cheap ones though. Especially in such a heavy application. They won't last, and they won't work well. Stick to a mid or upper product line from a well known quality company. Rancho is fine, but so it Gabriel and Monroe.
For brakes, I did Powerstop 1click brake kits for both the front and rear. I got mine from either Autoanything or RockAuto; I don't remember which. It has drilled and slotted rotors, red powder coated calipers, and I chose the Z36 extreme truck and tow ceramic pads. I use ceramic pads on anything I do brakes on, assuming they are available for the application. Much better fade resistance, and a lot less brake dust.
