Shocks and brakes
For shocks - I haven't done them yet but am leaning towards the Rancho's as well. I like the ability to adjust if necessary and like you have heard good things about their overall performance. I have Rancho 5000s on my Bronco and they are very stiff but they handle very well and have lasted so far about 5 years.
I primarily use my Ex as a tow vehicle...plain and simple.
In the winters I use it to go 4 miles each way to work so I very rarely drive her in an unloaded fashion.
For this reason I opted to save a few $$$ and went with the Bilsteins. At the time when I was looking I got my Bilsteins for about $65 each shipped to my door whereas the Rancho 9000XL's I was looking at were going to cost me nearly $100 each shipped to my door...so I figured the adjustability wasn't worth it for me...now if you do not tow all the time and want the ability to adjust to a somewhat softer ride and if that were my case...I would easily pop for the extra on the Rancho's and not think twice about it!...so it is all personal choice. For me the Bilsteins give me very nice towing performance...I noticed an immediate reduction of body porposing while towing after installing the Bilsteins...they really dampen out the inputs of the tongue on a bouncy road!
But others on here have reported a somewhat harsher ride with Bilsteins...that may be...but for me I seldom drive around without the 1100#'s of tongue weight tagged on the back that it is hard for me to tell...On the brakes...
I have fought brake rotor 'pulsation' on this Excursion since I got her. The first time the dealer turned the original rotors at 24,000 miles under warranty...that made the pulsation go away but it returned within 3 or 4000 miles. I eventually really heated up the rotors on one descent coming down a mountain pass just outside of Moab Utah when I wasn't paying full attention to what I was doing...got VERY HAIRY to say the least!!!...the pulsation after that incident was horrible...but upon returning home knowing it was time to replace the rotors...I opted to go with a set of Bendix rotors for $40 each up front but I also installed a set of Hawk LTS pads. There is a theory on here that I subscribe to...it is that the pulsation we feel is not a true rotor warpage as it is more of shedding brake pad material shedding and embedding in the hot surface of the rotors causing a 'rough' rotor surface over time...as your pads ride over this 'rough' surface...you feel the pulsation.
Many on here are very happy with their cryo rotors...however for me I didn't want to shell out $150 each for the front axle plus the $75 for the Hawk LTS pads...instead I spent $80 total on rotors and $75 on pads...since then I have logged about 5000 miles on the Ex with about 3000 of that towing thru some small hills in the northeast...thus far the brakes are just as smooth as when I installed them.
My theory is that even if the theory on here is wrong about the brake pad material shedding...I can turn these rotors one time each, buy new rotors and if needed even turn them once each and still have approximately the cost of ONE cryo rotor outlay...sure I have some of my time and labor...but I figured it was worth the gamble...braking performance is excellent with the Hawk LTS and Bendix rotor combo...this is just my $0.02
Good luck,
Joe.
