carb issues
Old Jul 11, 2015 | 10:37 PM
stevegraveli's Avatar
stevegraveli
carb issues
Hi All. I have an 87 F-250 5.8 HO 4Bbl. I just replaced the timing gears, chain, cover, water pump, fuel pump, t-stat. I now have an issue at idle. the engine starts to run rich, smoking exhaust, and then the fuel begins to "percolate" out of the bowl vents, and the engine dies. Timing is spot on and engine runs fine at higher RPMs. Does anyone else think I might have gotten a bad fuel pump?
Old Jul 13, 2015 | 12:49 AM
xlt4wd90's Avatar
xlt4wd90
Did you set the fuel level in the bowls? It sounds like it may be too high, or the needle valve is leaking.
Old Jul 13, 2015 | 10:33 PM
baddad457's Avatar
baddad457
Sounds like the floats are stuck. Tap on the adjustment nut/screw and see it that unsticks the float. On second thought, that's a 4180, it may not have an adjustable needle/seat. If so, might be a good time to replace it with a 4160 Holley that's fully adjustable.
AjRanger88
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 11, 2016 10:41 PM
stevegraveli
Jul 12, 2015 01:47 PM
sirfranky
Jul 21, 2006 12:13 AM
GBAKER
Nov 16, 2004 04:27 PM
bdclark
1978 - 1996 Big Bronco
Nov 9, 2003 08:37 PM
