fuel pump or timing problem
Old Nov 12, 2004 | 02:14 PM
GBAKER's Avatar
GBAKER
I hope you guys can help. I have a 63 F100 straight 6, probably a 223. I recently replaced the fuel pump and now she won't start. It wants to start but just will not start and stay running. It is getting plenty of fuel to the carb. but I am wondering if replacing the fuel pump has affected the timing somehow. It really acts like the timing is off. It was running fine until the fuel pump went out. Also, it was really easy to change the fuel pump and I wonder if I did it right. If it is getting plenty of fuel to the carb. the fuel pump must be installed right. Right? Any suggestions? (Carb is 1 barrell recently rebuilt).
Old Nov 12, 2004 | 04:17 PM
nealjpage's Avatar
nealjpage
Could it possibly be a flooding issue? The reason I wonder is because I don't see how changing a fuel pump chould change the timing and perhaps your new pump is delivering more fuel than the old one. Maybe as the old one started to get ineffecient the mixture screws or float settings were changed? Just a hunch.
Old Nov 12, 2004 | 04:20 PM
1949f1's Avatar
1949f1
bring up # 1 on the compression stroke , check the mark on the grank and on the rotor in the dist cap. sometimes when you shut them off if timeing chain or gears are worn they will jump after shutting off.
Old Nov 12, 2004 | 05:04 PM
Rosati's Avatar
Rosati
If your only change was the fuel pump, it's your problem.
If you rebuilt the carb and changed the fuel pump as well.
Old Nov 13, 2004 | 06:26 PM
Dads 66's Avatar
Dads 66
Possibly the fuel pump was only part of the problem. I would definately check the timing and ensure the carb is adjusted and is not part of the problem causing a flooded situation. Just replacing the fuel pump should have no direct impact on the timing.
Old Nov 14, 2004 | 04:29 PM
mst009's Avatar
mst009
Are you noticing any leaking around the carb. I have seen many a times where there is a rotten gasket or even just a loose carb and air is being sucked from the wrong place while at the same time, a little gas is leaking out from the carb.
I drove my 66 for many a miles with the carb just sitting on the intake manifold and the nuts over 1/4 inch backed off. I could actually grab the air cleaner and move the entire carb, and the truck still ran pretty well, just sputtered when I turned corners.
Just something to check before you go replacing stuff. You might put new points in also. Always try the cheap and easy fix first.
Good luck.
Old Nov 16, 2004 | 04:27 PM
Prowler68's Avatar
Prowler68
I have a 66 with the inline six and I just replaced the fuel pump as well and the carb was rebuilt now with all the new parts my truck was getting too much fuel so it ran poorly so I had to remove the front bowl (float cover) and ajust the little finger that the needle valve sits on, just take a small screw driver and slightly bend it upwards, this helped with my flooding problem and the truck runs fine now, hope this helps ya a little.
F350dog
33
Oct 24, 2024 12:53 PM
Bear13861
Mar 20, 2017 11:30 AM
grasfarmr73
Oct 29, 2015 04:27 PM
kpc3my
Sep 28, 2015 05:53 PM
08gasurveyor
Feb 6, 2013 03:48 PM
