Remove and reinstall filter
Old Jul 10, 2015 | 06:51 PM
bookem15's Avatar
bookem15
When I bought my truck recently they changed the oil for me while I waited but now I find the importance of using oem filter but I am not sure what they used. Will it hurt anything to remove the filter to check? Also does it have motorcraft stamped on it or any identifying marks?
Old Jul 10, 2015 | 06:57 PM
69cj's Avatar
69cj
It won't hurt anything. When you pull the filter it opens a drain valve and the housing will be empty. Motorcraft or Racor filters are good.
Old Jul 10, 2015 | 07:45 PM
bookem15's Avatar
bookem15
Ok so I took it off and the cap would not come off filter. So stupid question do you buy filter with new cap or do you have to get aggressive to separate them? I did not see anything telling me the manufacturer so it think I am just going to Change the oil and filter.
Old Jul 10, 2015 | 07:48 PM
POS Camaro's Avatar
POS Camaro
It sounds like you have the aftermarket filter. To go back to stock Ford, you will also need to buy a new cap along with the filter.
Rusty Axlerod's Avatar
Rusty Axlerod
Does it have a tall or short cap?
Old Jul 10, 2015 | 08:36 PM
bookem15's Avatar
bookem15
Yep the filter on the left is what mine looks like
Old Jul 10, 2015 | 09:10 PM
bookem15's Avatar
bookem15
Will this cause any issues or damage? Also where is best place to get new cap?
Old Jul 10, 2015 | 10:07 PM
bismic's Avatar
bismic
It can lead to damage IMO. Go back to all OEM.
Old Jul 10, 2015 | 10:14 PM
bookem15's Avatar
bookem15
When I looked at the picture above I got a sick feeling in my stomach and the only way to make myself feel better is do an oil change and get correct cap and filter. I have a 50 mile round trip and will use the motorcycle to get the stuff to do it.
Old Jul 11, 2015 | 04:58 AM
Rusty Axlerod
The filter on the left is at least "filtering" if it's still as it came out of the box. The worst combination is using the tall cap with the shorter Motorcraft filter under it. No filtering is going on with that combo. Motorcraft part number 2016 and the short cap is what you want. Raycor is the manufacturer for Ford and sells the same filter under their brand that is fine also. Fram used to license the exact same filter also but now sells one with some adapters in the box to make it work, those are to be avoided also.
Old Jul 11, 2015 | 04:10 PM
bookem15's Avatar
bookem15
Well that sick feeling is gone. $90.00 in oil 40 for oem cap 20 for filter. Piece of mind is priceless.
Thanks all for the help.
Old Jul 11, 2015 | 04:43 PM
69cj's Avatar
69cj
Good luck with your new truck.
frenchy750
Dec 20, 2010 06:20 PM
bhd
6.4L Power Stroke Diesel
15
Mar 23, 2010 10:26 PM
whporwil
Aug 19, 2009 09:07 PM
messeswithtrux
Mar 13, 2008 09:18 PM
F350marshall
Jul 31, 2005 01:15 PM
