Wiring harness question?
Old Jul 10, 2015 | 04:46 PM
52' fordnut's Avatar
52' fordnut
Hello,
In the process of wiring my 52 Ford F1 I came across a wire from the EZ wiring kit that I bought that is an accessory wire that needs to be wired to the accessory terminal of the key switch. I'm using my original key switch and there isn't an accessory terminal on the key switch.
Any idea as to where the accessory wire should attach? I'm wanting to think the battery terminal on the key switch but I'm not positive. I'm using the push button starter in conjunction with the key switch.
Thank you for your help!
Jon
Old Jul 10, 2015 | 04:57 PM
drptop70ss's Avatar
drptop70ss
Normally the ACC circuit is for powering limited items on the car whereas the key on position powers up everything. Is this a modern style truck or more original with limited electrical items? What do you have wired to run off the ACC power feed, or maybe you do not have anything that needs it? The only thing I could see using the ACC feed is the radio for say going to the drive in or just listening to it while sitting in the truck. You wouldn't want to just sit in the truck with the key on the "key on" position, especially if you have a points style ignition.
Old Jul 10, 2015 | 05:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The GAUGE terminal on the original switch is the corollary to ACC. I have everything related to running (ignition, tach, etc) on the IGN terminal and all the accessories (radio, heater, wipers) on GA.
Old Jul 10, 2015 | 05:19 PM
52' fordnut
Drptop70ss, it's basically just the original truck with just a new harness. I may be able to omit the wire, I just wanted to be sure of where it went and you actually answered my unspoken question of what the Accessory wire controlled.
Thanks!
thewheelman
Nov 8, 2016 08:49 PM
79super460
Jan 7, 2013 04:30 PM
ssj7kids
13
May 6, 2008 11:09 PM
n8rfreak4x4
1966 - 1977 Early Broncos
Jul 14, 2004 09:18 PM
a500ponies
Feb 11, 2004 03:18 PM
