starting problem
Old Feb 10, 2004 | 05:27 PM
a500ponies's Avatar
a500ponies
ignition
well my 79 f150 finnally ran ... but only when i hold the key all the way on ie ... in the start position not good for the starter so what do i look for now.... i changed the ignition switch it made no difference ...where do i look for the problem ... thanks 500 ponies ...
Old Feb 10, 2004 | 05:49 PM
a500ponies's Avatar
a500ponies
starting problem
well my 79 f150 finally runs well sort of ... it will run if i hold the key at the start position only ...hard on the starter but when i let go of the key to the run position it dies ... i changed the ignition switch so thats one thing less to check but where do i look now ...
Old Feb 10, 2004 | 06:49 PM
78fordman's Avatar
78fordman
Check the wiring, hook a testor up to the connector which connects to the red wire on the Ignition module and see if you still have power, you probably won't when the key is on, but you will have it when the key is in the start position. You should have power when the key is on. Probably something wrong in the wiring harness. I would find a wiring diagram of the key switch, and find that wire and run a new wire going to the ignition module.
Old Feb 10, 2004 | 06:53 PM
ranger429's Avatar
ranger429
did you check for voltage at the coil?
Old Feb 11, 2004 | 03:06 PM
a500ponies's Avatar
a500ponies
well i have power at the coil and it fires when i hold the key in the start position ... but no power at the modual with the key on ... .ie the red and black stripe wire .. so now where do i go from here .. does any one have a diagram of a 79 truck from the ignition switch to the control box ..any help would be apreciated
Old Feb 11, 2004 | 03:18 PM
a500ponies's Avatar
a500ponies
i forgot and yes i have power at the white wire when cranking thanks 500ponies..
