shimmy/ shake
Old Jul 10, 2015 | 10:03 AM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
shimmy/ shake
My 05 F250 tires are wearing funny (cupping). Dealer told me shocks need replacing (Original shocks, truck has 130k). My truck just started developing a shimmy/shake. When you start off from a dead stop the front rocks a bit like I have flat tire. When I get over 30-40 mph it goes away??? is this a shock issue or something else?? Thanks
Old Jul 10, 2015 | 12:55 PM
Iaff113's Avatar
Iaff113
shimmy/ shake
Every time I have had that start to rock at low speeds it has been the start of a tire bulge. It's also not fun to have it completely bulge out at 65 mph on the intestate
Old Jul 10, 2015 | 05:21 PM
Kemicalburns's Avatar
Kemicalburns
I thought there was a recent TSB on this shimmy issue?
Old Jul 10, 2015 | 05:40 PM
Maxium4x4's Avatar
Maxium4x4
Look the whole front suspension over but really cupping is shocks. The side to side sway when first rolling indicates a pulled belt. I would not put off checking that out since steering is involved. Or rotate the back to front ASAP. With the tire off your one bolt away from checking out the shock.
Old Jul 11, 2015 | 03:29 AM
Stroker 6.0 fan
Thanks for the reply guys. Took it to tire shop, found that left rear tire had a bulge in it, not sure why it did that. New tire solved the issue.
jimatrps
Aug 4, 2019 08:35 PM
dustyroad
Apr 28, 2019 07:15 PM
Curtis M
Feb 21, 2008 10:20 PM
THE KING
Mar 5, 2007 08:42 PM
mike L
Nov 4, 2004 09:28 PM
