240 vs 300 ID
Old Jul 9, 2015 | 09:11 PM
fljab's Avatar
fljab
240 vs 300 ID
Hey all
I've got a line on a big six engine that could be a 240 or a 300.
As far as I know, the only way to tell which one is to pull a plug, put something in the combustion chamber (like a white stiff housewire) and measure the stroke.
It supposedly came out of a '66 truck and I believe that the 240 was standard with the 300 optional; sound right? The truck is long gone.
It's an hour+ away from me so just doing my homework before I go there. The seller is less than cooperative and says he doesn't have time to do the stroke check -
TIA!
Old Jul 9, 2015 | 09:29 PM
85e150's Avatar
85e150
#$%^&*() 'em.
It's a 240 if he won't check.
Billions served, keep looking and tell him that.
Old Jul 9, 2015 | 11:17 PM
farmall99's Avatar
farmall99
Check the crank pulley. 240's had a 2 groove pulley while the 300's had a 3 groove pulley. That's how I found my 240 head.
Old Jul 10, 2015 | 06:14 AM
fljab's Avatar
fljab
Looking at the picture, it looks like a 1 groove pulley.
Yes, I'm after the head and not sure what else; I'm rebuilding a EFI engine now to replace the tired one in my '85 F150. I want to build another engine for a hot rod truck as the next project so some 240 parts would be great.
I think I'll try and get him down on price some more and go look at it.
Old Jul 10, 2015 | 11:05 AM
The Frenchtown Flyer's Avatar
1-groove=240
Old Jul 10, 2015 | 01:05 PM
fljab's Avatar
fljab
Originally Posted by The Frenchtown Flyer
1-groove=240
Thanks FF! I need to make the trip down there to get it for sure
EDIT: I offered the guy $100 for the engine; waiting to see if he takes it.
Old Jul 14, 2015 | 09:00 AM
fljab's Avatar
fljab
I made it back with my prize 240 engine. $100 + gas (~6 gallons), Not a bad score I don't think esp if the head is OK + whatever else I should want off of it. Now to build a dolly for it and roll under my workbench until I need it.
I see the oil pan is different than the two 300s I have (original in my '85 F150 4x4, the other a '88 I bought used). This engine supposedly came out of a '66 truck and was changed out yrs ago for a 289/auto. The truck is long gone; I bought the engine from the owners son who got tired of kicking this thing out of the way. He has some other old engines, but no Ford. I saw a 50s Olds engine and not sure what else.
Old Jul 15, 2015 | 06:41 AM
Good find. Check the casting number on the head located under the thermostat. The third digit must be an "A" to be the smaller 68 cc 240 head.
Old Jul 15, 2015 | 07:43 AM
fljab's Avatar
fljab
Those numbers are very difficult to read, but it looks like "C6AE - ?" There also appears to be another number/letter on the other side of the head adjacent to the numbers above (if I'm making sense). I may have to pull the head to know for sure.
I pulled the valve cover and at the front just inside where the gasket would be is a "6C30". A round area with numbers is nearby and at the back is a large "A". I know the first two mostly likely are casting date codes; not sure about the big A.
The block has a "C6AE - 6015 - D"
Old Jul 15, 2015 | 07:45 AM
The C6AE head is the smaller cc 240 head. You win!
Old Jul 15, 2015 | 07:51 AM
fljab's Avatar
fljab
WooHoo! Thanks for the decode help FTF!
I have a '88 300 I'm rebuilding right now that was supposed to be a "good used running engine" and has just been a money pit, but it should be on the up and up now.
I'm glad I finally got a good deal on one of these old engines - well, pending machine shop crack check, but I'm confident this time. No plans to tear it apart just yet; I'm going to just put it away until I need it fully assembled, altho I may pull the plugs and try to rotate and lubricate the engine and inside of the intake/exhaust ports of the head with some WD40 or similar.
Old Jul 15, 2015 | 09:31 PM
Use marine fogging oil, not WD40.
Old Jul 15, 2015 | 10:11 PM
85e150's Avatar
85e150
Originally Posted by 85e150six4mtod
#$%^&*() 'em.
Congrats, thought you wanted a 300. Silly me. Good luck with it!
Old Jul 16, 2015 | 06:10 AM
fljab's Avatar
fljab
Thanks, I'll go get some.
Edit: I have some fogging oil on order (Amazon)
Old Jul 16, 2015 | 06:14 AM
fljab's Avatar
fljab
I'm mainly after the head. Dunno right now if I need the rest of it, but I'm storing the entire engine under my workbench for the time being.
After I get the current 300 rebuilt and into my '85 F150 4x4, then the engine that's in there now will be built up for much more performance and the 240 head will be utilized.
64rustbucket
Dec 8, 2011 10:40 PM
89whitenight
Dec 6, 2009 10:45 PM
Supercab
Jan 3, 2009 12:06 AM
savage066
Nov 26, 2005 12:33 AM
whittey
Jan 11, 2002 08:02 AM
