engine grounds
Old Jul 8, 2015 | 12:58 PM
sean9049's Avatar
sean9049
engine grounds
on the drivers side of the engine,is the ground that goes from motor to battery neccesary to keep? will every thing without it? TIA
Old Jul 8, 2015 | 02:39 PM
madpogue's Avatar
madpogue
Um, without that ground, how do you expect that battery to help start the truck?
Old Jul 9, 2015 | 08:19 AM
sean9049's Avatar
sean9049
thats why i asked i didnt know what it does, now i know its needed thanks
Old Jul 9, 2015 | 10:28 AM
kupiec20's Avatar
kupiec20
I just change my fenders and rad support
Correct me if I'm wrong.
One ground goes to the fender (pass side) and the other goes to the rad support?
Old Jul 9, 2015 | 05:04 PM
Ken_C's Avatar
Ken_C
Heres some wiring diagrams for our trucks. the ones titled Ground distribution will show how your grounds are wired and the location of every grounding point on your truck. A lot of electrical problems can be attributed to crappy ground connections. Its generally a bad idea to CREATE a bad ground. Dont do it. https://www.ford-trucks.com/forums/1...l#post11383134
Old Jul 9, 2015 | 06:09 PM
sean9049's Avatar
sean9049
Thank you guys for the help, to the battery like it used to be it is...looks like ill need more cable
turk1994
Oct 18, 2016 08:50 PM
wyoming4x4
Mar 22, 2011 09:49 PM
ct50f1
Oct 27, 2010 03:43 AM
BryanE
Jan 17, 2010 04:19 PM
earnies2
Dec 6, 2005 09:41 AM
