Hot radiatator support?
Old Dec 6, 2005 | 09:23 AM
earnies2's Avatar
earnies2
This is a new one on me. the other night while plowing the altonater crapped out, when i opened the hood to check the belt and wires i put my hand on the rad support right in front of the drivers side battery and it was hot???158 on my laser temp tool batt termanals were warm on both sides rad support was only hot for about a 12 inch aera there is a fender ground there i took it off and cleaned it i also cleaned the aera where the support and the fender attach all my battery cables are clean and tight truck starts and runs great im baffled? I know its not right and if i dont fix it it will caus a problem at the worst tine any susjestions???????
Old Dec 6, 2005 | 09:41 AM
Brians97F250Crew's Avatar
Brians97F250Crew
I would suggest just double checking all your grounds. Make sure the chassis to block straps are there and are good. Sounds like there is a difference in potential somewhere on the front or there is a dead short somewhere might be why the alt crapped out on you.
