2015 Information Display DTE calculation error?
Old Jul 13, 2015 | 01:49 PM
  #31
AlexWV's Avatar
AlexWV
I just checked this on my 3.5EB. Changed it back and forth a few times sitting in the driveway with the engine off.
DTE normal 719
DTE tow 681 <-- less than normal mode, seems right to me it should be less for towing
DTE normal 730 <-- normal mode changed, wtf?
DTE tow 681
DTE normal 730
I wouldn't use DTE to know when to fill up in any case. For that I use the "gallons used" in Trip 1 meter which I reset every time I fill up.
I did that for years in my last F350 and literally never looked at the fuel gauge. If you know how far off the "gallons used" is over a tank (and in my case it always indicated less used than actual used), you can pretty much tell to the ounce how much you have left.
Also, as an experiment, I ran DTE down to 0 to see what would happen since I knew I had fuel left. And what happened was nothing. It just sat on 0.
I use DTE like a video game to keep me entertained while driving. I add trip miles + DTE and that is High Score. So far on this F150 my high score is 768. I think I can get that into the 800s
Old Jul 27, 2015 | 02:34 PM
  #32
kenttrudiw's Avatar
kenttrudiw
I believe this works as it should. I know have over 1300 towing miles on my Truck. When I have the Truck DTE on towing my miles drop according to my 12 miles or so per gallon. When I change it to regular, it jumps up to the unloaded average of about 19 or so. I thought this was very useful on my 800 mile trip when I towed my boat. Now I need to remember to change it back to normal for the Wife.
Old Aug 1, 2015 | 08:45 AM
  #33
Gary Lewis's Avatar
Gary Lewis
I recently used the tow/haul mode on the transmission to do some mountain driving, and since I wasn't actually towing or hauling the average indicated MPG was in the 19's. But my to-date normal mode indicated MPG is more like 18. Sure enough, when I changed the DTE calculation to "tow" the distance to empty jumped up, and when I put it back to "normal" it came down again.
So, my guess from that limited observation is that the DTE calc uses the average to-date MPG for the tow/haul mode in the transmission to generate the "tow" distance. And, it uses the to-date indicated MPG from the "normal" mode of the transmission, and perhaps including Sport mode" to generate the other distance.
If that's true, then using the tow/haul mode of the transmission when you aren't actually towing or hauling can significantly mess up the DTE calculation.
Old May 31, 2024 | 06:35 AM
  #34
LC27028's Avatar
LC27028
2nd Gear
distance to empty issue
hello everyone, i am new to FTE. i have a 2015 F350 DRW 4x4 Platinum and i have an issue i cannot find any information anywhere on the internet. i recently had to replace both batteries and I am not sure if this is related or what. i just filled the tank up yesterday and my miles to empty on my cluster is showing only 85 miles to empty. is there a way to reset this or to find out what is going on here?
EDIT: i did forget to mention that the fuel gauge is reading full the only thing that if is off or has an issue is the DTE reading as far as i can tell
Old May 31, 2024 | 10:29 AM
  #35
JKBrad's Avatar
JKBrad
Welcome to FTE LC27028,
You dredged up and old thread and you seem to have a problem that's not related to those who want precise calculations on their fuel mileage/DTE readings. Also, you have a Super Duty, which has a somewhat different electrical system. I would suggest that you go to the 1999-2016 Super Duty forum, which can be found on the main forum page, then make a new thread there.
Here's a link to that forum.
https://www.ford-trucks.com/forums/forum30/
VA13FX4
Jul 3, 2018 09:44 AM
bjarnold1
6.7L Power Stroke Diesel
Jan 21, 2018 01:47 PM
danr1707
Aug 19, 2017 03:59 PM
Help I M Stuck
Sep 14, 2006 09:50 PM
hdway
Jun 10, 2005 12:09 PM
