This is the only 6.0 I have owned. My tranny temp (with the Torque Pro) is pretty much always the same as my ECT. My ECT will move, and less than 2 seconds later, the tranny will move to the same temp. Is this normal? I was expecting lower tranny temps, but maybe it should be the same because of sharing the radiator. Thoughts?
I used the other one at first but it did not show any temp. This one has always ran the same as coolant. The dash gauge has never been past the middle either.
I get actual numbers from both PIDS in my TorquePro app. One is the same as what I get from the DashDAQ (around 165 as stated above), and the other is noticeably higher. I will look at it tomorrow to see if it tracks coolant temps.
Torque has 2 different Trans fluid temps. (method 1 and method 2) One is bogus and tracks the coolant temp exactly. OBD2 Header as AUTO. Method 2 is the one to use. That one Has the OB2 Header as TCM which is Transmission Control Module.. imagine that!
yeah I remember being more of them now. I have selected the setting "Hide unsupported sensors" on mine so I don't see those 2 anymore. glad you got it working.
