Pinging 95 7.5
Old Jul 4, 2015 | 11:21 AM
5851a's Avatar
5851a
Pinging 95 7.5
Bought 95 extended drw F350 couple of years ago and just use for pulling camper. Had straight pipes with cat first year and drove maybe 500 miles. Replaced exhaust with stock duals and now it's camp ground quiet but I can hear it pinging. Going to get it out tomorrow if it doesn't rain and check timing. 87 octane around here and I use the ethanol free due to storing it most of the time. This thing has been a pita since I bought it, brakes transmission, too rough for the other half and performance wise hasn't lived up to my expectations. Any ideas for the timing setting?
Old Jul 4, 2015 | 11:46 AM
rla2005's Avatar
rla2005
Factory is 10 BTDC w/SPOUT removed.
Old Jul 4, 2015 | 12:53 PM
5851a's Avatar
5851a
Thanks I'll start from there.
Old Jul 4, 2015 | 08:44 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
I had to back mine down to stock 10 degrees and have to run 89 to stop mine from pinging. It'll ping even with 89 at 12 degrees.
Old Jul 5, 2015 | 07:03 AM
Diesel_Brad's Avatar
Diesel_Brad
You can also run a can a seafoam thru it to cut down on the carbon buildup
Old Jul 5, 2015 | 10:08 AM
wtroger's Avatar
wtroger
I would look for vacuum leaks and make sure the coolant temp isn't to high. Also Real gas is more prone to spark knock than E-10. But I agree if truck is of low use then E-10 should be avoided.
Old Jul 6, 2015 | 01:48 AM
badaz4570's Avatar
badaz4570
Originally Posted by Diesel_Brad
You can also run a can a seafood thru it to cut down on the carbon buildup
Think he meant "Seafoam."
Old Jul 6, 2015 | 04:04 AM
Diesel_Brad
LOL, YES. Dam spellcheck
SpeedThrills
May 4, 2016 09:11 AM
SoCalAngler
Nov 25, 2014 05:38 PM
DIYiT
Aug 22, 2011 12:15 PM
bigsky22
May 22, 2007 06:47 PM
Tiggie
1983 - 2012 Ranger & B-Series
Apr 16, 2005 10:00 PM
