I have an 89 F-150 5.0 and i'm trying to get the timing set at a point i'm happy with. It ran terrible on 87 octane, and not too great on 89, so i was forced to run 91. I thought i'd try adjusting the timing to get it to run on cheaper gas, and maybe get a little more performance (if thats possible at the same time). I know its set at 10 degrees btc stock, and it was right on when i checked with the light. i decided to bump it up a little, and its right around 14-15 now if i understand it correctly. I noticed a pretty decent jump in acceleration after this, but it still runs better on 91. it makes a little different noise running 89 and i can tell over the sound of no muffler. i'm kind of in the dark about where to set it. i'd like it to run on cheaper gas if possible, and i'd like to see a little performance boost without burning through my cylinder walls. any input would be awesome. Thanks.
yeah that the way its looking. any ideas why it only runs on 91? and when i say it only runs on 91, i mean it. it has no power running 87, and gets worse mileage anyway.
There could be any number of more serious issues. Your timing chain could be wearing out, your engine could be full of carbon, you could have cracked heads, a sensor somewhere could be bad, etc.
Or it could be something simple like the distributor being off a tooth.
I have read in some older posts that after resetting the timing, and changing to the new lower octane gas, remove the negative battery cable for about a half hour.
This resets the computer and it relearns your engine and it's sensors.
It might idle or run funny the first few times you start, run and warm it up as the computer reprograms itself.
i may give that a try. the octane problem isnt anything serious. i know that because the truck rips for an 89 5.0. it hasnt been abused either. the only thing i think thats possible is an old timing chain. thanks for your inputs.
