6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Help. White smoke plus engine sounding weird.
Old Jul 1, 2015 | 04:18 PM
powerstrokecowgirl's Avatar
powerstrokecowgirl
My truck blew a decent amount of white smoke today and this isnt the first time and lately my truck has been making different noises then normal . This happens when im hauling things. recently the last few days ive noticed its making those same noises while on the flat and not hauling anything. What could be going on? Or what should I do. Ive heard many different things from turbo going to injectors. Help!! It also has less then 140,000 miles on it.
Old Jul 1, 2015 | 06:29 PM
Maxium4x4's Avatar
Maxium4x4
Can you give us a little history of repairs, was this during a regeneration. White smoke can be fuel, or odd things like high humidity. Is the truck throwing a code, any drivability concerns? Noise coming from the engine while under load or anytime like at idle?
The guys will be along to help and any information can help diagnose what you may be experiencing.
Old Jul 1, 2015 | 06:32 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Or head gaskets. I'd park it and get it (towed) to a garage that knows about the 6.4 diesels. Not all shops know about these motors. Have you checked the oil or antifreeze?
Old Jul 2, 2015 | 09:07 AM
caprang's Avatar
caprang
So any time its really humid or raining, or just if my truck sits for a few days, the first time I build any boost it blows white smoke like its on fire. Its just condensation in the intercooler and it only lasts 10 seconds or so. This is normal from what I have read. Others have stated after cruising a constant speed for a while, then taking off from a stop (building boost) they may see this. again mostly associated with rain or humidity.
The other possibility as mentioned is head gaskets/coolant. Is your level low? Do you see any white splatter/residue under your hood? Can you smell coolant? Any leaks anywhere?
Do you still have the DPF? Could the truck be trying to regen and there is an issue?
Old Jul 2, 2015 | 02:01 PM
powerstrokecowgirl
Correction its actually blueish colored smoke.
Old Jul 2, 2015 | 07:08 PM
Maxium4x4's Avatar
Maxium4x4
Ok Blue is oil, your turbo seal could be shot since you have a noise. We need a little history and when this is happening.
Old Jul 3, 2015 | 07:01 AM
powerstrokecowgirl
shortly after I start it for the day. I dont know much history on this truck sorry
Old Jul 3, 2015 | 07:22 AM
CampSpringsJohn
My truck is making some noise, but no smoke. And it varies too. Blue smoke is oil like Maximum 4x4 said. I'd get it to a shop ASAP and figure out exactly what the problem is.
SkoalDipperJoe
May 16, 2016 09:55 AM
Excurvelle
Oct 14, 2014 07:48 PM
markpl
Jul 1, 2009 09:56 AM
myboysrmyheart
Oct 30, 2007 04:58 PM
dorsetmerv
Sep 23, 2005 07:20 PM
