hi guys!
1999 expy, 145k. has white smoke coming from exhaust, engine run grate,
help!!
some upgrade: after changing all plugs, clean up carburator(last week),
changing fuel filter, engine start with no problems, except white smoke,
car was sitting for 2 weeks, after all work drive for 30 minutes(white smoke),
today start engine smoke gone drive like champ, oil look normal, coolant level OK for
now, engine work great. Any idea!???
you might have a valve seal that is leaking, and when the truck sits for long periods of time, it allows oil to accumulate in the cylinder. When you changed the oil, it might have dis=lodged whatever caught in the seal.
When oil burns it creates blue smoke not white. White smoke is essentially steam and is a result of heated water. So unless he is misdiagnosing the color of the smoke, it is coolant that is getting into a cylinder and not oil.
