Hey jim,
Thanks for the awsome Tip. Problem is, there is no relay in this Manuel For ac. only a fuse, i checked, its ok.
how could this be? know about 2relay's in a chevy astro 😔
folks i need a tip please 👀
There is a A/C Comp Clutch Relay listed at NAPA Auto Parts online. ECH AR671 for $18.49, it's fairly small and looks like it could be inline on the Wire Harness somewhere. And I found a A/C Control Relay ECH AR272 that looks like it's in a Fuse Block or Power Dist Box $16.49..........
Could this be the WOT relay that drops the A/C clutch during WOT? I think that relay is inline, maybe mounted below the distribution box?
Just guessing.
jim
i had a look for the damn relay. havnt found it. i was following the wires behind the engine near the doghouse. nothing. im not able to find this god damn AC relay -.- why is it not in the relay box or written down in the Ownermanual or rep. Manual
Since you're doing much of your own electrical diagnosis and repair I'd strongly recommend buying a factory manual or EVTM for your year van body/chassis.
Along with showing the actual wiring paths there are component location guides to show you here different things are actually located.
Here in the USA AutoZone has free schematics but you have to register which is very easy pain free.
still nobody knows the Location of the A/C relay? :,(
The schematic you need might be available free of charge through Autozone.com. You'll have to register (give them an email address) but afterwards you'd have access to their library.
PM me about sending you an EVTM---glad to do it for anyone in need of service documents, especially not living in the USA.
