Sponsored by: Real Truck
A/C Help
Old May 25, 2010 | 10:17 PM
timster24's Avatar
timster24
A/C Help
Does anyone know where the relay is for the A/C clutch control? From what I can find it is located in Axillary relay box 4, however I do not know where it is located, does anyone here know where it is located? Any help will be appreciated
Old May 27, 2010 | 07:18 PM
timster24's Avatar
timster24
I still have not been able to locate where it is, does anyone have any ideas. I know its not in the main fuse/relay block, is there any secondary blocks floating around the truck. I know on mid to late 90's RBV they are located by the pass headlight but have not found anything in that area of the truck
Old Jun 26, 2010 | 03:45 PM
bentcipher's Avatar
bentcipher
A/C Clutch Relay is in the fuse box by the driver's side fender firewall. Once you open the lid, you will see smaller fuses on the left and large relays on the right (facing the windshield from the front of the vehicle). The relays on the right (from top to bottom are) PCM power relay, A/C Blower Relay, and A/C Clutch Relay (#32).
Page 176 of your Owners Manual (you can download it free at https://www.fleet.ford.com/maintenan...ls/default.asp)
Hope this helps.
Old Jul 2, 2010 | 05:12 PM
Birdup's Avatar
Birdup
Hope this helps.
Thanks for the download link
