9" Pinion Support Retainer ?
Old Jun 29, 2015 | 07:04 PM
c391d's Avatar
c391d
I was replacing the oil seal in the pinion support retainer over the weekend and managed to crack and break off a couple pieces where the seal presses in. I now need to find a new or good used one. My truck is a 78 F150 4x4. Are these 9" retainer plates all the same in 2WD's, 4WD's and cars? Or do I need to look for a certain one?
Old Jun 29, 2015 | 08:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What are you referring to, 4614? If so, there are TWO different types.
Look at approx. 5 o'clock under one of the bolts that retains the carrier to the housing for the rear axle tag. Post the code stamped on it.
Old Jun 29, 2015 | 10:13 PM
c391d's Avatar
c391d
The rear axle tag reads,
WDM-BZ 7JB
3 50 9 390B
The numbers cast onto the plate (4614) are 2317 and D2SW-C
Thank you for the help.
Old Jun 30, 2015 | 01:59 AM
NumberDummy
WDM-BZ
D2SZ-4614-A .. 9" Retainer & Bearing Cup / Obsolete
1973/79 F100 & 1975/79 F150 with all WDM (except WDM-AM - WDM-AM2 - WDM-AN - WDM-AN2) and all WEW
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
farmboy555
Jan 27, 2026 05:29 PM
john jamieson
Feb 15, 2016 04:51 PM
xtal_01
Jul 18, 2014 09:50 AM
liljohn320
Feb 3, 2013 07:16 PM
bluestang65
Sep 10, 2010 03:45 PM
