Need Part number info.
Old Jan 31, 2013 | 01:40 PM
liljohn320's Avatar
liljohn320
I am in the process of changing the rear in my 50 F1. I have a 70 F100
rear from the junk yard. It needs axle bearings and seals also a Pinion
seal. I think i have the right part numbers from past posts.
C9AZ-1225A for the bearings. EOTZ 1177C for the Seals. Please
correct me if they are not right. I've checked sizes they seem to
be right. But I can't check the size of the pinion seal. I'm taking it to a
shop to get the work done and have to take the parts too. If anybody
could help with the part number for this seal would be great also does it
need a crush bearing ?
Thanks
Old Feb 2, 2013 | 05:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The following is assuming the 1970 F100 9" has a 9" ring gear, because some 1968/72 F100's came w/a 9" that has a 9 3/8" ring gear. With 5* exceptions, the parts do not interchange!
All these parts can be bought from autoparts stores, I doubt you'll find them at a Ford Dealer. Most autoparts stores haven't a single clue inre to Ford part numbers.
EOTZ-1S177-CA (replaced EOTZ-1177-C, C9AZ-1177-A & B7A-1177-A) .. 9" Axle Seal / 1957/83 F100 / 1966/86 Bronco / 1969/86 E100/150 / 1975/86 F150.
D8AZ-1225-C (replaced C9AZ-1225-A & C1SZ-1225-A & B) .. 9" Axle Ball Bearing-Large / 1961/83 F100 / 1966/86 Bronco / 1969/86 E100/150 / 1975/86 F150.
The bearing has a BIN (Bearing Industry Number) stamped on it. All you gotta do is take that number to any autoparts store to get the correct bearing.
B7A-4662-A .. 9" Crush Sleeve / All 1957/86.
E2TZ-4676-A (replaced D4AZ-4676-A, D1UZ-4676-A & C2AZ-4676-B) .. 9" Pinion Seal-3" O.D. x 1 13/16" I.D. / 1962/83 F100 / 1966/86 Bronco / 1969/86 E100/150 / 1975/86 F150.
* 9 vs 9 3/8 = ONLY 5 parts are the same: Housing gasket, pinion seal, pilot bearing retainer, one pinion bearing and cup. EVERYTHING else is different!
Note: Some 1974/79 9's came w/a tapered roller axle bearing/seal combination.
The above parts were also used in misc 9" Passenger Cars, but it would take me one hour to list all the applications.
Old Feb 2, 2013 | 08:11 PM
liljohn320's Avatar
liljohn320
Bill
Thank you so much for the numbers.
Actually according to the tag it is a 8.7 ring gear.
I believe all bearings and seals are the same.
Can a 8.7 ring and pinion be replaced with a 9 inch?
I don't see any after market ring and pinions that
are 8.7. Sorry for all the questions.
Thanks for the help.
John
Old Feb 3, 2013 | 12:17 AM
NumberDummy
Some I-6 F100's have a 9" w/a 8.7" ring gear. Pinion seal, axle bearings/seals are the same.
What is the code on the rear axle ID tag? There are two different types of differential bearings.
The bearings and cups will have BIN's stamped on them.
Old Feb 3, 2013 | 03:53 PM
liljohn320's Avatar
liljohn320
Bill
Numbers on plate are WDM AC OHC
3.25 8.7 317A
I'm hoping I can get a Ring and Pinion to get down to 3.70
Numbers on axle bearings are BCA 208F SEAL
Thanks
John
Old Feb 3, 2013 | 06:52 PM
NumberDummy
Originally Posted by liljohn320
WDM-AC OHC (OHC: Assembled the 3rd week (C) of August (H) 1970 (0)) 3.25 8.7 317A
I'm hoping I can get a Ring and Pinion to get down to 3.70. Numbers on axle bearings are BCA 208F= D8AZ-1225-C
The parts are the same as listed in post 2. 8 3/4" and 9" ring gear use the same case.
This 9" has the newer (changed mid-year 1969) "slim line" differential bearings/cups, same thru 1986.
(2) C9AZ-4221-A .. Differential Bearing / Marked with BIN: LM102949
(2) C9AZ-4222-A .. Differential Bearing Cup / Marked with BIN: LM102910
Old Feb 3, 2013 | 07:16 PM
liljohn320's Avatar
liljohn320
Bill
Thanks so much for your help.
John
1918ALF
May 19, 2019 09:13 PM
markeyd
Jun 5, 2016 08:36 PM
aprosody
34
Mar 3, 2013 12:09 PM
jrohr
Sep 17, 2010 09:22 PM
347mack
Dec 28, 2009 07:31 PM
