1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2015 250 rode rough so I checked tire pressure, Wow!
Old 06-30-2015, 08:43 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I'm running 68lbs in mine because if I get too much lower the TPMS will trigger the warning light. I'd like to be able to run less when empty but I got tired of looking at the light and having to clear the message on the dash everytime I started the truck.
A good method to get the proper air pressure is to draw a line across your tire with chalk and slowly drive forward on a hard level surface. At the proper air pressure the chalk will wear off even across the tire.
Old 06-30-2015, 01:09 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Originally Posted by Pit Crew
Air pressure is all over the board. How is it we don`t get premature tire wear. Back in the day tires called for 32 lbs.35 would wear the center and 29 would wear the edges. I realize tires have come along way, but these are some big differences.
This is the empty rule of thumb that
I still go by. But then my ride is the 85
Bronk with 10.5X 31. It rids and wears well.
Old 06-30-2015, 07:03 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
could that tire be damaged from over inflation?
Old 06-30-2015, 07:34 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
If it suffered damage, it would've blown with that kind of pressure.
Old 06-30-2015, 07:47 PM
walter white's Avatar
walter white
walter white is offline
i had to have the parameters reprogrammed in mine when discount tire sold me tires that were max inflate 55 psi for a truck that wants much higher pressure. i would love nothing more than to shove those tire sensors up some engineer's tail pipe
Old 07-01-2015, 05:10 AM
redford's Avatar
redford
redford is offline
Received 1,581 Likes on 922 Posts
So, Discount Tire sold you 8-Ply tires for a 10-Ply truck then?
Old 07-01-2015, 07:08 AM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
Mr. Mcbeevee is offline
It sounds like someone aired the tire up to seat the bead and forgot to let the pressure back down.
Old 07-02-2015, 04:31 AM
walter white
yes, they sure did. 35" nit grapplers in load range d. they paid for a ford dealer to reprogram and made some promises for my next set of tires. i buy a lot of truck,trailer and car tires from that store manager but i gave them hell over it. you would think a red flag would pop on their screen that shows this tire is not compatable with that truck but i guess not. i could understand it if they were a shop that sometimes also does tires
Old 07-02-2015, 04:33 AM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
I have the same tires (Nitto Trail Grapplers) in load range "E". 35x12.5x20. Too bad they didn't get it right.
Old 07-02-2015, 04:43 AM
walter white
yep. when i change tires again, i have to have it re-reprogrammed
as embarrasing as it is to admit, this isn't the first time those rocket surgeons have screwed up tires for me. they put "regular" tires on a prius my wife used to have instead of the super light "eco" tires. it made the car shift funny and could cause chaos in that hybrid system. they may not know what they're doing but they fix their mistakes i suppose.
Old 07-02-2015, 06:14 AM
Tom's Avatar
Tom
Tom is offline
Not really. It was an 8-ply equivalent tire. http://www.tirerack.com/tires/tirete....jsp?techid=55
Originally Posted by TireRack.com
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
A little off-topic, but there is no shifting that occurs in a Prius. It's a fixed planetary gear system, there are no gears to shift! Were they the correct size?
Old 07-02-2015, 12:26 PM
walter white
They were a workable size but way too heavy. I guess it caused it to run rough and when the wife found out they could damage hybrid battery and nulls toyo warranty.,everybody involved (esp me) had to hear about it. Discount tire swapped them no questions asked
  #28
Old 07-02-2015, 07:24 PM
jtruck618's Avatar
jtruck618
jtruck618 is offline
So dealers can change the threshold? I have read mixed things in this.
lebby83
22
01-15-2023 10:50 AM
kupaa
08-18-2010 03:44 PM
rb8484
04-01-2009 10:24 AM
kmccune
28
08-03-2008 08:33 PM
TexasGuy001
11-19-2002 08:22 AM
Quick Reply: 2015 250 rode rough so I checked tire pressure, Wow!
