2015 250 rode rough so I checked tire pressure, Wow!
My left tires had 120psi front and back and the right had 80psi. I have 7000 miles on it. I admit I haven't check the tire pressures previously. My question is how the left two got that much over inflated. It hasn't been anywhere but the dealer and my shop.
I know from experience and 3 trucks with tpms sensors on the stems, you have to hold a tire gauge correctly and check more then once per tire. If Ford isn't going to use the sensors it would be safer to leave them off entirely.
Do you have a faulty tire pressure gauge? I know heat will cause them to raise pressure, and I have seen some garbage trucks I used to work on that had tires rated to 130psi, and we maxed them out. On a hot day when they would come in, they exceeded my 150psi gauge. To go from 80 to 120 is a lot!
Mine came from the dealer with 55 psi in all the tires. The tires say 80 & the door tag says 65. I upped the pressure to 70 & thought it rode way too rough. I also thought it did steer good when it was wet out. Every few days I've been letting a little air out to find the best ride. I'm down to 62 psi & think I'll stay there. I wonder if someone was playing a joke on you?
always go by the door sticker. that is a recommended pressure based on your particular vehicle no matter the max rating of the tire itself.
the rating on the tire is a max value.
When i bought my 08 in June of 09, upon getting it home home and thinking the same that it was sure rough riding. My front tires were at 110 and back at 95.
Air pressure is all over the board. How is it we don`t get premature tire wear. Back in the day tires called for 32 lbs.35 would wear the center and 29 would wear the edges. I realize tires have come along way, but these are some big differences.
