PCV change 351 - easiest thing I've done
I have a leaking rear main and I was told to try to change the PCV to make sure that wasn't causing it but I read it was a real pain. I can do some stuff so I thought id try it and Ill tell u what on my truck it was so easy it's laughable. Literally a 5 min job. I don't think my old one was bad but maybe the 5.0 is way harder to get to but man was mine easy
I didn't replace that. Is that necessary? I didn't have any codes or it isn't running bad but I replaced the pcv because I read to try that if the rear main is leaking first to see if it makes a difference
on
It can be done with the plenum in place- BUT- I recommend picking up a grommet (HELP! aisle at the parts store, on one of their little red cards) and the UPPER PLENUM gasket: it is only a dollar or two, and removing the plenum. It is very little trouble, and allows you to clean up the valve cover, as well as any other crud on top of the engine at the same time...
Below is the 5.8l (351W) which is nearly identical to the 5.0(302), and you can see the PCV arrangement at the back left corner)
Scott
Seriously though yeah I've tried to get to mine and it didn't look fun w/o removing the upper intake. The hose was squishy so I left it for another day. Good to know it ain't that bad but I'm still gonna yank the intake anyway. I think I have a vacuum leak somewhere (besides that PCV hose) and I'm determined to find it cause I lost like 2 MPG's lately.
DJdemon6696
04-15-2007 06:29 PM
