Sponsored by: Auxito
Do I need new hood?
Old Jun 28, 2015 | 08:05 PM
bbsitum's Avatar
bbsitum
Do I need new hood?
Small metal plate that is behind hood hinge is rotten. I do not see way to replace just plate. Should I pay new hood or how is possible fix it?
Old Jun 29, 2015 | 06:14 PM
kd4gij's Avatar
kd4gij
Hit the local scrap yards.
Old Jun 30, 2015 | 08:48 PM
steve(ill)'s Avatar
steve(ill)
you could take hood off, turn upside down, cut out the bad area and wire feed a new plate to repair......... but might heat up or distort the hood or paint on the outside. Cheaper, but time consuming, and you need a welder ........ Replacement hood might be faster.
Old Jul 2, 2015 | 07:56 PM
bbsitum's Avatar
bbsitum
I come with idea I will just screw some metal plate from bottom of hood. Need not weld nothing nor take apart. Evidently all 4 screws will go soon or lather. Do not like go to junkyard as will not be capable to mach color. Again if hood hinges look so you need not ask about gates hinges and gates and that area of bed.
52' fordnut
15
Feb 9, 2013 09:50 AM
Strokerin
Mar 16, 2007 07:00 PM
94F150regcabMARKIII
May 14, 2005 08:40 PM
jvmcc
Jul 21, 2004 07:43 AM
