drivers side headlight is very dim or not even working with new bulbs.
Occasionally it will come on .High beam light is always very dim until you click high beams then its bright blue
Bad plugs at the lamp can do that.
Here is the wiring diagram for the 2006 year for the head lights.
Here is also one for the auto lamps. I also tacked on the relay and fuse PDF.
Let me know if you need others.
is there anyway to run a hot wire as a temp?possibly off the passenger side light ?..need to go out of town to pick something up and dont have time to trace this out
