Aerostar Ford Aerostar
power door locks
Old Jun 28, 2015 | 07:37 AM
zenish's Avatar
zenish
power door locks
my drivers door lock quit working.all the others still respond to the drivers door switch.the motor works when on the bench.one of the wires has broken or lost connection.anyone suggest where to check first?
Old Jun 28, 2015 | 02:34 PM
xlt4wd90's Avatar
xlt4wd90
A bundle of wires go through an accordion tube from the door to the frame. That's the most common area of wire failures, as that's where they get repeatedly bent the most.
Old Jun 29, 2015 | 10:07 AM
Jose A.'s Avatar
Jose A.
yes, that is where the wire(s) break, from the driver's door entry point into the kick panel.
Old Jun 29, 2015 | 04:55 PM
zenish's Avatar
zenish
thanks.thats what i was thinking too.its almost impossible to access those wires in the door.
Old Jul 4, 2015 | 08:59 PM
Jose A.'s Avatar
Jose A.
not really, just pull the driver's side plastic cover or "kick panel",
with door open, pull the rubber "accordion" neck from both sides,
remove door panel, leaving door locks switch handy.
remove some of the wiring harness tape at the point where it enters the interior, that's where you will find any broken wires.
TruckinAL
1997 - 2003 F150
May 22, 2016 09:17 PM
kev70ss
1997 - 2003 F150
Apr 7, 2010 08:02 PM
kahnos
Jun 13, 2006 12:52 AM
dmacfordshot04
Sep 6, 2005 12:45 AM
Guy
Jul 7, 2002 03:23 PM
