Lower Intake 5.8/351 performance
Old Oct 9, 2015 | 01:16 AM
  #31
broncobear's Avatar
broncobear
This should be my 5th post and then I can post a pic of what I've put together so far. I already have an Explorer 65 mm TB, so if 65 mm won't create a vacuum in the upper plenum during WOT, then I should be OK. If I bog or get a vacuum reading, I'll have to go BBK 70 mm.
IS a factory 70 mm and 70 mm EGR plate?
I don't plan to change the 5.8 lower manifold. Just restick it with a new gaskets and a 1/4" bead fr & Rr to avoid seal slide out. This $500 drop-in engine project has near $1000 of stuff I will need. Going with an aftermarket lower is just not in the plan.
Old Oct 9, 2015 | 07:10 AM
  #32
JRS2's Avatar
JRS2
Broncobear:
Ok, let us know what the results are. I don't believe we asked if it was only stock or built somewhat ..... if you care to provide details that is fine as well ...
Old Oct 9, 2015 | 11:52 AM
  #33
broncobear's Avatar
broncobear
The engine is a stock 5.8 from an F350 with 120k, and an E4OD.
I need to get an ECM (A9L I think) for Manual Transmission.
Last post correction: Is there a factory 70 mm TB and EGR plate?
Old Oct 9, 2015 | 02:05 PM
  #34
Mudsport96's Avatar
Mudsport96
I read this whole thread and was wondering, what vehicle this is going in? I may have missed it
Old Oct 9, 2015 | 02:37 PM
  #35
broncobear's Avatar
broncobear
1971 "Bronconator"
It's going into my 1971 early Bronco (non-smog). I run desert, forest trails, and rock crawl. That's why I need torque between 1500-3000.
Bronconator has super low gearing 435 (6.67 1st gear)-203 doubler range box (doubles any gear ratio)-Dana 20 (2.56), into 4.11 9", turning 37" Goodyear MTRs.
This is in Big Bear on Holcomb Creek climbing up a 10' ledge.
Old Oct 9, 2015 | 06:00 PM
  #36
Mudsport96's Avatar
Mudsport96
If you aren't revving over 3500-4000 I would think that even the stock 5.8 manifold would be sufficient. Being in a crawler, 95% of your driving is under 40% throttle. And as for a computer, even a 351 computer for a 351/c6 combo would work.
Old Jul 22, 2017 | 01:33 PM
  #37
ohio45344's Avatar
ohio45344
Hey ULTRARANGER do oyu still have the lower intake for the marine 5.8? If so would you sell it, I am looking for one
burton7.3
Apr 3, 2013 09:27 AM
bradleycharris
Apr 30, 2010 05:16 PM
hotrodlincoln69
Oct 13, 2009 01:26 PM
Squam74
Jun 6, 2008 07:19 PM
Jrock909
Feb 14, 2007 08:57 AM
